Up to 20% off select tools
Motorola Droid Turbo Display Assembly Replacement
Views: 18K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
116
All Time:
17,877
Comments: 31
23 comments on steps, 8 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the display assembly on your Motorola Droid Turbo. If your replacement display assembly does not include a earpiece speaker, you'll need to swap your existing one over to it.
    1. Motorola Droid Turbo Display Assembly Replacement, Rear Case: step 1, image 1 of 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Ask FixBot
    2. Motorola Droid Turbo Display Assembly Replacement: step 2, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Ask FixBot
    1. Motorola Droid Turbo Display Assembly Replacement, Midframe: step 3, image 1 of 1
      • Remove the midframe bezel.
      Ask FixBot
    2. Motorola Droid Turbo Display Assembly Replacement: step 4, image 1 of 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Ask FixBot
    3. Motorola Droid Turbo Display Assembly Replacement: step 5, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Motorola Droid Turbo Display Assembly Replacement, Earpiece Speaker: step 6, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement, Earpiece Speaker: step 6, image 2 of 2
      • Use a Jimmy to pry under the speaker and lift to remove it.
      • Be sure to place your tool under the entire speaker assembly, against the plastic frame, and pry there.
      • These photos show an incorrect tool position—prying this high up on the speaker assembly may damage it. Place your tool underneath the speaker assembly, not on the edge as shown here.
      • The speaker is secured with some light adhesive, so some force may be required.
      Ask FixBot
    1. Motorola Droid Turbo Display Assembly Replacement, Battery: step 7, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement, Battery: step 7, image 2 of 2
      • Use the point of a spudger to pop up the battery connector.
      Ask FixBot
    2. Motorola Droid Turbo Display Assembly Replacement: step 8, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 8, image 2 of 2
      • Fold the wireless charging coil away from the battery.
      Ask FixBot
    3. Motorola Droid Turbo Display Assembly Replacement: step 9, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 9, image 2 of 2
      • Use a spudger to gently pry the battery up from the rest of the device.
      • The battery is secured with some moderate adhesive, so some force may be necessary.
      Ask FixBot
    1. Motorola Droid Turbo Display Assembly Replacement, Display Assembly: step 10, image 1 of 1
      • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
      Ask FixBot
    2. Motorola Droid Turbo Display Assembly Replacement: step 11, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 11, image 2 of 2
      • Remove the lower antenna board.
      Ask FixBot
    3. Motorola Droid Turbo Display Assembly Replacement: step 12, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 12, image 2 of 2
      • Remove the SIM card holder/volume button rocker.
      Ask FixBot
    4. Motorola Droid Turbo Display Assembly Replacement: step 13, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 13, image 2 of 2
      • Carefully lift up the motherboard to expose the display connector.
      Ask FixBot
    5. Motorola Droid Turbo Display Assembly Replacement: step 14, image 1 of 2 Motorola Droid Turbo Display Assembly Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
      • Pull the display ribbon cable free of the connector.
      Ask FixBot
17 other people completed this guide.
Author
with
Geoff Wacker
93,223 Reputation
88 Guides authored
8 Guide Comments
This has a bunch of unecessary steps and is missing so,e just kinda bricked my phone thanks to this
fake name - Reply Share
Yep. It repeats a bunch of steps, and seems to switch from replacing the display to replacing the motherboard. :(
Richard Klein - Reply Share
has anyone ever had the buttons break on this phone? i know on my old droid maxx one little mistake when putting the board in the metal frame was enough to break the volume buttons.
Dudefoxlive - Reply Share
You don’t need to remove the battery from the board…the whole thing comes up as one.
Jason Stewart - Reply Share
What if your screen is glitchy after the install?
Help me J - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 116
All Time: 17,877
