Motorola Droid Turbo Battery Replacement
    1. Motorola Droid Turbo Battery Replacement, Rear Case: step 1, image 1 of 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Ask FixBot
    2. Motorola Droid Turbo Battery Replacement: step 2, image 1 of 2 Motorola Droid Turbo Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Ask FixBot
    1. Motorola Droid Turbo Battery Replacement, Midframe: step 3, image 1 of 1
      • Remove the midframe bezel.
      Ask FixBot
    2. Motorola Droid Turbo Battery Replacement: step 4, image 1 of 1
      • Remove the four Torx T5 screws securing the midframe plate.
      Ask FixBot
    3. Motorola Droid Turbo Battery Replacement: step 5, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Motorola Droid Turbo Battery Replacement, Battery: step 6, image 1 of 2 Motorola Droid Turbo Battery Replacement, Battery: step 6, image 2 of 2
      • Use the point of a spudger to pop up the battery connector.
      Ask FixBot
    2. Motorola Droid Turbo Battery Replacement: step 7, image 1 of 2 Motorola Droid Turbo Battery Replacement: step 7, image 2 of 2
      • Fold the wireless charging coil away from the battery.
      Ask FixBot
    3. Motorola Droid Turbo Battery Replacement: step 8, image 1 of 2 Motorola Droid Turbo Battery Replacement: step 8, image 2 of 2
      • Use a spudger to gently pry the battery up from the rest of the device.
      • The battery is secured with some moderate adhesive, so some force may be necessary.
      Ask FixBot
60 other people completed this guide.
Victor Chapman
393 Reputation
1 Guide authored
USF Tampa, Team 15-5, Remmell Spring 2016 Member of USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 Members
48 Guides authored
34 Guide Comments
The screws that attach the black plastic in step 3 are NOT #2 phillips. This is reasonably obvious from the photo but the misleading caption should be changed. They are T5 Torx bit screws. Also, the plastic camera sub assembly in step 4 has 3 small t shaped tabs that shear if you pry it away from the phone. I could not see a way to remove the sub assembly without damaging the tabs so the 4 T5 screws will have to keep it in place from now on.
Jeffrey Sauter - Reply Share
Hey Jeffrey! Thanks for the heads up. Feel free to edit the guide steps as you see fit by selecting Edit in the top right corner of the guide step in question. We changed the permissions so you should be able to edit the text. Thanks again for contributing!
Kelsea Weber - Reply Share
Do you need to apply fresh adhesive when re-assembling?
Richard Klein - Reply Share
Do you need to apply adhesive when re assembling?
ben_martell - Reply Share
the adhesive is 3 narrow pieces of double sided tape. You can carefully peel it off the old battery and reuse it. I don't see where it's absolutely necessary though. The battery isn't going to move around after the phone is put back together.
Mike Mangiaruca - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 121
All Time: 88,092
