Up to 20% off select tools
Motorola Droid Rear Case Replacement
Views: 42K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
111
All Time:
41,692
Comments: 1
1 comment on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • T5 Torx Screwdriver
    4.9
Introduction
Go to step 1 ↓
This guide will take you through the delicate process of removing the rear panel of the Motorola Droid.
    1. Motorola Droid Rear Case Replacement, Battery: step 1, image 1 of 3 Motorola Droid Rear Case Replacement, Battery: step 1, image 2 of 3 Motorola Droid Rear Case Replacement, Battery: step 1, image 3 of 3
      • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
      • Lift and remove the battery cover out from the phone.
      Ask FixBot
    2. Motorola Droid Rear Case Replacement: step 2, image 1 of 1
      • Grasp the upper left corner of the battery and lift it out of its housing.
      Ask FixBot
    1. Motorola Droid Rear Case Replacement, Rear Case: step 3, image 1 of 1
      • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
      • The cover is attached by adhesive, so some force may be required.
      Ask FixBot
    2. Motorola Droid Rear Case Replacement: step 4, image 1 of 2 Motorola Droid Rear Case Replacement: step 4, image 2 of 2
      • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
      • Peel the ribbon up off the phone.
      Ask FixBot
    3. Motorola Droid Rear Case Replacement: step 5, image 1 of 2 Motorola Droid Rear Case Replacement: step 5, image 2 of 2
      • Carefully peel the device information label that covers the motherboard EMI shields.
      • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
      Ask FixBot
    4. Motorola Droid Rear Case Replacement: step 6, image 1 of 1
      • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
      • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
      Ask FixBot
    5. Motorola Droid Rear Case Replacement: step 7, image 1 of 1
      • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
      Ask FixBot
    6. Motorola Droid Rear Case Replacement: step 8, image 1 of 1
      • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
      Ask FixBot
    7. Motorola Droid Rear Case Replacement: step 9, image 1 of 1
      • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
      • Carefully pry the top edge of the rear case up from the rest of the phone.
      Ask FixBot
    8. Motorola Droid Rear Case Replacement: step 10, image 1 of 2 Motorola Droid Rear Case Replacement: step 10, image 2 of 2
      • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
      • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
      Ask FixBot
    9. Motorola Droid Rear Case Replacement: step 11, image 1 of 2 Motorola Droid Rear Case Replacement: step 11, image 2 of 2
      • Continue prying the rear case from the front case along the left side, moving from bottom to top.
      • Lift the rear case up out of the phone.
      Ask FixBot
6 other people completed this guide.
Author
with
Brett Hartt
132,682 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 111
All Time: 41,692
