Motorola Droid RAZR Motherboard Replacement
    1. Motorola Droid RAZR Motherboard Replacement, Back Cover: step 1, image 1 of 2 Motorola Droid RAZR Motherboard Replacement, Back Cover: step 1, image 2 of 2
      • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
      • Pry the back cover up with the plastic opening tool to free the plastic clips.
      • Continue prying along the left edge of the back cover towards the top of the phone.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 2, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 2, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 2, image 3 of 3
      • Work the plastic opening tool across the top of the back case to free the plastic clips.
      • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
      • Continue prying down the right side of the back cover to free the remaining clips.
      Ask FixBot
    3. Motorola Droid RAZR Motherboard Replacement: step 3, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 3, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 3, image 3 of 3
      • Pull the back cover away from the phone to remove it.
      • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
      • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
      • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Battery: step 4, image 1 of 2 Motorola Droid RAZR Motherboard Replacement, Battery: step 4, image 2 of 2
      • Use the tip of a spudger to lift up the red silicone cover over the battery terminal screws and remove it.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 5, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 5, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 5, image 3 of 3
      • Remove the two 3.3 mm T5 Torx battery terminal screws.
      • Grab the blue battery removal tab and lift the battery out to remove it.
      • There is quite a bit of adhesive securing the battery to the motherboard. Work slowly to avoid deforming the battery.
      • Your phone will have a number of metal EMI shields on the motherboard, rather than the bare ICs seen here.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Camera Cover: step 6, image 1 of 2 Motorola Droid RAZR Motherboard Replacement, Camera Cover: step 6, image 2 of 2
      • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
      • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
      • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
      • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
      • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 7, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 7, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 7, image 3 of 3
      • Insert the plastic opening tool underneath the top edge of the camera cover.
      • Gently pry the camera cover up as you slide the plastic opening tool across the top edge to free it from the adhesive.
      • Remove the camera cover.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Rear Case: step 8, image 1 of 1
      • Remove the six screws securing the rear case to the rest of the phone:
      • three 6.7 mm silver T3 Torx screws at the top,
      • four 4.0 mm gold T3 Torx screws in the middle,
      • and three 4.5 mm black T5 Torx screws at the bottom.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 9, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 9, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 9, image 3 of 3
      • Insert a plastic opening tool between the rear case and the motherboard assembly.
      • Work your way down the side of the phone and gently pry the rear case up.
      • Separate the rear case from the motherboard assembly.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Motherboard Assembly: step 10, image 1 of 2 Motorola Droid RAZR Motherboard Replacement, Motherboard Assembly: step 10, image 2 of 2
      • Remove the three 2.5 mm T3 Torx screws securing the metal chassis to the motherboard.
      • Remove the metal chassis from the motherboard assembly.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 11, image 1 of 2 Motorola Droid RAZR Motherboard Replacement: step 11, image 2 of 2
      • Use the flat end of a spudger to remove the two red silicone microphone covers at the top and bottom of the motherboard.
      Ask FixBot
    3. Motorola Droid RAZR Motherboard Replacement: step 12, image 1 of 1
      • There is a small metal shield that covers the display assembly cable connectors on the motherboard. This shield is held in place by a few small clips that attach to the surrounding EMI shields.
      • Use the tip of a spudger to gently bend the clips out of shape and remove the shield.
      Ask FixBot
    4. Motorola Droid RAZR Motherboard Replacement: step 13, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 13, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 13, image 3 of 3
      • Use the flat end of a spudger to pry the three display cable connectors off their sockets on the motherboard.
      Ask FixBot
    5. Motorola Droid RAZR Motherboard Replacement: step 14, image 1 of 2 Motorola Droid RAZR Motherboard Replacement: step 14, image 2 of 2
      • There are a number of small black plastic clips on the display assembly that hold the motherboard in place.
      • Release the securing clips with a plastic opening tool.
      Ask FixBot
    6. Motorola Droid RAZR Motherboard Replacement: step 15, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 15, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 15, image 3 of 3
      • Use a heat gun or hair dryer to soften the adhesive strip around the perimeter of the motherboard.
      • Pry the edges of the motherboard up from the display assembly with a plastic opening tool.
      • Remove the motherboard assembly.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Rear-Facing Camera: step 16, image 1 of 2 Motorola Droid RAZR Motherboard Replacement, Rear-Facing Camera: step 16, image 2 of 2
      • Lift up the anti-static tape covering the camera and earpiece ZIF connectors with the tip of a spudger.
      • Peel back the tape and remove it.
      • Unless you have spare ESD-safe tape lying around, you may consider keeping this piece somewhere safe to be reused at reassembly.
      Ask FixBot
    2. Motorola Droid RAZR Motherboard Replacement: step 17, image 1 of 3 Motorola Droid RAZR Motherboard Replacement: step 17, image 2 of 3 Motorola Droid RAZR Motherboard Replacement: step 17, image 3 of 3
      • Use a plastic opening tool or your fingernail to lift up the tab on the rear-facing camera ribbon cable ZIF connector.
      • Make sure you're prying on the tab and not the connector itself.
      • Push the rear-facing camera through its hole in the grey antenna and remove it.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Front-Facing Camera: step 18, image 1 of 3 Motorola Droid RAZR Motherboard Replacement, Front-Facing Camera: step 18, image 2 of 3 Motorola Droid RAZR Motherboard Replacement, Front-Facing Camera: step 18, image 3 of 3
      • Use a plastic opening tool or your fingernail to lift up the tab on the front-facing camera ribbon cable ZIF connector.
      • Lift the front-facing camera out of the antenna with the plastic opening tool and remove it.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Earpiece Speaker: step 19, image 1 of 3 Motorola Droid RAZR Motherboard Replacement, Earpiece Speaker: step 19, image 2 of 3 Motorola Droid RAZR Motherboard Replacement, Earpiece Speaker: step 19, image 3 of 3
      • Flip up the tab on the earpiece speaker ZIF connector with your finger or a plastic opening tool.
      • Make sure that you are prying on the tab and not the connector itself.
      • Remove the earpiece speaker from the motherboard.
      Ask FixBot
    1. Motorola Droid RAZR Motherboard Replacement, Motherboard: step 20, image 1 of 1
      • The motherboard remains.
      Ask FixBot
11 other people completed this guide.
David Hodson
156,742 Reputation
127 Guides authored
1 Guide Comment
Does anybody do charging port repairs on a droid razor ?
I don't have the tools and would rather donate so somebody who has them.....
Chuck - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 40
All Time: 23,516
