Motorola Droid RAZR Maxx Battery Replacement
    1. Motorola Droid RAZR Maxx Battery Replacement, Removing the battery: step 1, image 1 of 2 Motorola Droid RAZR Maxx Battery Replacement, Removing the battery: step 1, image 2 of 2
      • Remove the SIM card.
      • Remove the microSD card.
      • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
      • Do this along the back right side of the phone cover until you reach the top.
      Ask FixBot
    2. Motorola Droid RAZR Maxx Battery Replacement: step 2, image 1 of 2 Motorola Droid RAZR Maxx Battery Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
      • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
      • After this continue using the tool and pry down the remaining side and the bottom of the phone.
      Ask FixBot
    3. Motorola Droid RAZR Maxx Battery Replacement: step 3, image 1 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 3, image 2 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 3, image 3 of 3
      • With all the plastic clips released, pull away the back cover from the phone to remove it.
      • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
      • The back cover is very durable and will not break from some bending or pulling.
      Ask FixBot
    4. Motorola Droid RAZR Maxx Battery Replacement: step 4, image 1 of 1
      • Looking at the top rectangular hump where the camera is located, use the plastic opening tool to remove the camera cover.
      • Using the plastic opening tool, apply pressure into any surrounding crease of the camera cover to remove it.
      Ask FixBot
    5. Motorola Droid RAZR Maxx Battery Replacement: step 5, image 1 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 5, image 2 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 5, image 3 of 3
      • Using the T5 and T4 bit pieces, remove the silver screws located around the rear case of the phone.
      • Remove the three 6.7 mm silver T4 screws that are located at the top of the phone.
      • Remove the five 4.0 mm silver T5 screws that are located near the middle of the phone.
      Ask FixBot
    6. Motorola Droid RAZR Maxx Battery Replacement: step 6, image 1 of 1
      • Using the T5 bit piece remove the three black 4.5 mm screws that are located at the bottom of the phone.
      Ask FixBot
    7. Motorola Droid RAZR Maxx Battery Replacement: step 7, image 1 of 2 Motorola Droid RAZR Maxx Battery Replacement: step 7, image 2 of 2
      • Insert the plastic opening tool between the rear case and motherboard assembly.
      • Using the plastic opening tool, carefully work your way around the phone, freeing the plastic clips.
      • Carefully pull the rear case off the motherboard assembly.
      Ask FixBot
    8. Motorola Droid RAZR Maxx Battery Replacement: step 8, image 1 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 8, image 2 of 3 Motorola Droid RAZR Maxx Battery Replacement: step 8, image 3 of 3
      • Using the tip of the spudger, lift the red silicone cover off the battery terminal screws.
      • Remove the two 3.3mm T5 Torx battery terminal screws.
      • Grab the red battery removal tab and pull the battery out.
      • There might be some adhesive between the battery and motherboard assembly.
      Ask FixBot
9 other people completed this guide.
jean Florival
149 Reputation
1 Guide authored
USF Tampa, Team 14-6, Leahy Fall 2014 Member of USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Members
60 Guides authored
1 Guide Comment
can we put droid razr max battery with its cover in the xt912 (simple droid razr)
saif ur rehman - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 103
All Time: 10,691
