Motorola Droid RAZR Maxx Back Cover Replacement
    1. Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: step 1, image 1 of 2 Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: step 1, image 2 of 2
      • Remove the SIM card.
      • Remove the microSD card.
      • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
      • Do this along the back right side of the phone cover until you reach the top.
      Ask FixBot
    2. Motorola Droid RAZR Maxx Back Cover Replacement: step 2, image 1 of 2 Motorola Droid RAZR Maxx Back Cover Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
      • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
      • Continue using the tool and pry down the remaining side and the bottom of the phone.
      Ask FixBot
    3. Motorola Droid RAZR Maxx Back Cover Replacement: step 3, image 1 of 3 Motorola Droid RAZR Maxx Back Cover Replacement: step 3, image 2 of 3 Motorola Droid RAZR Maxx Back Cover Replacement: step 3, image 3 of 3
      • With all the plastic clips released, pull away the back cover from the phone to remove it.
      • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
      • The back cover is very durable and will not break from some bending or pulling.
      Ask FixBot
4 other people completed this guide.
sean crocker
341 Reputation
1 Guide authored
USF Tampa, Team 14-6, Leahy Fall 2014 Member of USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Members
60 Guides authored
2 Guide Comments
Ok so I have the cover off of the back of my Droid Razr Maxx HD? But where is it that I can purchase the new back cover? I figured you guys would have at least a hyper link to somewhere I could buy it? Instead of just having instructions on how to remove the backing? Thanks Very Respectfully, Joey K
sailorjt1985 - Reply Share
I have same problem. Need new back cover.
TheShellex - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 109
All Time: 3,279
