Motorola Droid RAZR M Battery Replacement
    1. Motorola Droid RAZR M Battery Replacement, Front Assembly: step 1, image 1 of 3 Motorola Droid RAZR M Battery Replacement, Front Assembly: step 1, image 2 of 3 Motorola Droid RAZR M Battery Replacement, Front Assembly: step 1, image 3 of 3
      • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
      • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
      • Close the latch once the two cards are removed.
      Ask FixBot
    2. Motorola Droid RAZR M Battery Replacement: step 2, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 2, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 2, image 3 of 3
      • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
      Ask FixBot
    3. Motorola Droid RAZR M Battery Replacement: step 3, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 3, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 3, image 3 of 3
      • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
      • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
      • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
      • Once the plastic cover is detached, pull the piece away with your fingers.
      Ask FixBot
    4. Motorola Droid RAZR M Battery Replacement: step 4, image 1 of 2 Motorola Droid RAZR M Battery Replacement: step 4, image 2 of 2
      • Remove the three T4 Torx screws. There are three at the bottom of the device.
      Ask FixBot
    5. Motorola Droid RAZR M Battery Replacement: step 5, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 5, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 5, image 3 of 3
      • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
      • As soon as you can get your finger underneath, pull away the silver plate.
      Ask FixBot
    6. Motorola Droid RAZR M Battery Replacement: step 6, image 1 of 2 Motorola Droid RAZR M Battery Replacement: step 6, image 2 of 2
      • Remove the two 7mm T4 Torx screws at the top of the device.
      Ask FixBot
    7. Motorola Droid RAZR M Battery Replacement: step 7, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 7, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 7, image 3 of 3
      • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
      • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
      • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
      • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
      Ask FixBot
    8. Motorola Droid RAZR M Battery Replacement: step 8, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 8, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 8, image 3 of 3
      • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
      • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
      • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
      Ask FixBot
    1. Motorola Droid RAZR M Battery Replacement, Motherboard: step 9, image 1 of 2 Motorola Droid RAZR M Battery Replacement, Motherboard: step 9, image 2 of 2
      • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
      Ask FixBot
    2. Motorola Droid RAZR M Battery Replacement: step 10, image 1 of 2 Motorola Droid RAZR M Battery Replacement: step 10, image 2 of 2
      • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
      Ask FixBot
    3. Motorola Droid RAZR M Battery Replacement: step 11, image 1 of 2 Motorola Droid RAZR M Battery Replacement: step 11, image 2 of 2
      • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
      • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
      Ask FixBot
    4. Motorola Droid RAZR M Battery Replacement: step 12, image 1 of 2 Motorola Droid RAZR M Battery Replacement: step 12, image 2 of 2
      • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
      Ask FixBot
    5. Motorola Droid RAZR M Battery Replacement: step 13, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 13, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 13, image 3 of 3
      • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
      • Use your fingers to gently pull the motherboard down and out of the rear casing.
      Ask FixBot
    1. Motorola Droid RAZR M Battery Replacement, Battery: step 14, image 1 of 3 Motorola Droid RAZR M Battery Replacement, Battery: step 14, image 2 of 3 Motorola Droid RAZR M Battery Replacement, Battery: step 14, image 3 of 3
      • Peel back the plastic from the face of the battery.
      Ask FixBot
    2. Motorola Droid RAZR M Battery Replacement: step 15, image 1 of 3 Motorola Droid RAZR M Battery Replacement: step 15, image 2 of 3 Motorola Droid RAZR M Battery Replacement: step 15, image 3 of 3
      • Pull up on the plastic to lift the battery out of the rear assembly casing.
      • There is adhesive securing the battery so you will need to apply a good amount of force.
      • Hold down the left edge of the rear assembly casing as you pull the battery out.
      Ask FixBot
12 other people completed this guide.
Thomas Fenner
515 Reputation
1 Guide authored
Cal Poly, Team 15-1, Amido Spring 2015 Member of Cal Poly, Team 15-1, Amido Spring 2015
CPSU-AMIDO-S15S15G1
4 Members
84 Guides authored
6 Guide Comments
Thank you! This phone is really well-built, and a bear to disassemble. This guide had exactly what I needed to see.
Roy Thomasson - Reply Share
this was a rockin' guide!!! looked everywhere and here it is, and yes a bear but a cool one!
apriltanner1975 - Reply Share
Thank You! Hope this new battery works better than the old one!
autococker13 - Reply Share
Yeah it's kind of helpful.
Sebastian ballensky - Reply Share
where will i get the battery for the my own phone now
Timothy - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 105
All Time: 9,324
