Motorola Droid RAZR HD Front Panel Assembly Replacement
    1. Motorola Droid RAZR HD Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Power off the device before disassembly to avoid damage or harm from electrical surges.
      • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
      Ask FixBot
    2. Motorola Droid RAZR HD Front Panel Assembly Replacement: step 2, image 1 of 1
      • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
      Ask FixBot
    3. Motorola Droid RAZR HD Front Panel Assembly Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to lift the screen from the phone.
      • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
      Ask FixBot
    4. Motorola Droid RAZR HD Front Panel Assembly Replacement: step 4, image 1 of 2 Motorola Droid RAZR HD Front Panel Assembly Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
      • Carefully lift up the black locking tab to release the lcd/digitizer cable.
      • The cable connector is located on the bottom right section of the phone.
      Ask FixBot
    5. Motorola Droid RAZR HD Front Panel Assembly Replacement: step 5, image 1 of 1
      • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
      • This connector is located on the top right section of the phone.
      • Use tweezers to lift the black bar on top of the ZIF connector.
      • Pull the ribbon cable out of the connector with tweezers.
      • Now that there are no cables connecting the screen to the motherboard, remove the screen.
      Ask FixBot
5 other people completed this guide.
Brendan Baronia
681 Reputation
2 Guides authored
Cal Poly, Team 4-4, Maness Spring 2015 Member of Cal Poly, Team 4-4, Maness Spring 2015
CPSU-MANESS-S15S4G4
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 99
All Time: 1,461
