Motorola Droid Pro Screen Replacement
    1. Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: step 1, image 1 of 2 Motorola Droid Pro Screen Replacement, SD Card/SIM Card PCB Board: step 1, image 2 of 2
      • Remove the back cover and battery by using the thumb tabs.
      Ask FixBot
    2. Motorola Droid Pro Screen Replacement: step 2, image 1 of 1
      • Unscrew the 8 back panel screws using the T4 Torx screwdriver.
      Ask FixBot
    3. Motorola Droid Pro Screen Replacement: step 3, image 1 of 1
      • Use a spudger to open the phone along the sides between the back panel and the chrome trim.
      • It is held together by small clips that lock in. You may have to use a little force to unlock them.
      • Go around on all sides then pull the back panel off.
      Ask FixBot
    4. Motorola Droid Pro Screen Replacement: step 4, image 1 of 2 Motorola Droid Pro Screen Replacement: step 4, image 2 of 2
      • Gently lift the SD & SIM card board (PCB) as shown in the following pictures.
      • This will expose the ribbon cable attached to the board and another ribbon cable for the mother board. Remove them both using the spudger.
      • Once the small one is removed the small board can be pulled off.
      Ask FixBot
    1. Motorola Droid Pro Screen Replacement, Screen: step 5, image 1 of 1
      • Unscrew the 6 screws using the T5 Torx screwdriver.
      Ask FixBot
    2. Motorola Droid Pro Screen Replacement: step 6, image 1 of 1
      • Unlock the ribbon cable and then you can pull the screen out.
      • When replacing screen make sure you lock the ribbon cable back in place.
      Ask FixBot
Peter Cakounes
19 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 21
All Time: 533
