Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
    1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover using the thumb tab located on the bottom of the phone.
      Ask FixBot
    2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 2, image 1 of 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 2, image 2 of 2
      • Remove the battery using the thumb tab.
      Ask FixBot
    1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: step 3, image 1 of 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: step 3, image 2 of 2
      • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
      Ask FixBot
    2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 4, image 1 of 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 4, image 2 of 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
      • It is held together by small clips that lock in. You may have to use extra force to unlock them.
      • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
      Ask FixBot
    3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 5, image 1 of 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: step 5, image 2 of 2
      • Gently lift the SD & SIM card board (PCB) as shown.
      • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
      Ask FixBot
2 other people completed this guide.
Kyle Shays
836 Reputation
4 Guides authored
UMass Dartmouth, Team 1-6, Miles Fall 2015 Member of UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Members
72 Guides authored
1 Guide Comment
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 652
