Up to 20% off select tools
Motorola Droid Pro Camera Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
98
All Time:
711
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Before continuing make sure you power down your device and work in a clean area. Also wear a static band to prevent damages to your device.
    1. Motorola Droid Pro Camera Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover using the thumb tab located on the bottom of the phone.
      Ask FixBot
    2. Motorola Droid Pro Camera Replacement: step 2, image 1 of 2 Motorola Droid Pro Camera Replacement: step 2, image 2 of 2
      • Remove the battery using the thumb tab.
      Ask FixBot
    1. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: step 3, image 1 of 2 Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: step 3, image 2 of 2
      • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
      Ask FixBot
    2. Motorola Droid Pro Camera Replacement: step 4, image 1 of 3 Motorola Droid Pro Camera Replacement: step 4, image 2 of 3 Motorola Droid Pro Camera Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
      • It is held together by small clips that lock in. You may have to use extra force to unlock them.
      • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
      Ask FixBot
    3. Motorola Droid Pro Camera Replacement: step 5, image 1 of 2 Motorola Droid Pro Camera Replacement: step 5, image 2 of 2
      • Gently lift the SD & SIM card board (PCB) as shown.
      • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
      Ask FixBot
    1. Motorola Droid Pro Camera Replacement, Motherboard: step 6, image 1 of 2 Motorola Droid Pro Camera Replacement, Motherboard: step 6, image 2 of 2
      • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
      • There are small tabs on the side of the connectors to wedge your tool under.
      Ask FixBot
    2. Motorola Droid Pro Camera Replacement: step 7, image 1 of 2 Motorola Droid Pro Camera Replacement: step 7, image 2 of 2
      • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
      Ask FixBot
    3. Motorola Droid Pro Camera Replacement: step 8, image 1 of 2 Motorola Droid Pro Camera Replacement: step 8, image 2 of 2
      • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
      • This cable is fragile so be careful when disconnecting and moving it around.
      Ask FixBot
    4. Motorola Droid Pro Camera Replacement: step 9, image 1 of 1
      • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
      Ask FixBot
    5. Motorola Droid Pro Camera Replacement: step 10, image 1 of 3 Motorola Droid Pro Camera Replacement: step 10, image 2 of 3 Motorola Droid Pro Camera Replacement: step 10, image 3 of 3
      • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
      Ask FixBot
    6. Motorola Droid Pro Camera Replacement: step 11, image 1 of 2 Motorola Droid Pro Camera Replacement: step 11, image 2 of 2
      • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
      Ask FixBot
    1. Motorola Droid Pro Camera Replacement, Camera: step 12, image 1 of 3 Motorola Droid Pro Camera Replacement, Camera: step 12, image 2 of 3 Motorola Droid Pro Camera Replacement, Camera: step 12, image 3 of 3
      • The camera is located on the back side of PCB board.
      • Flip the board over and you will see that the camera is connected by a ribbon cable.
      • Unlock the cable by using a plastic remover tool then pull the camera out.
      • Insert the new camera and re lock the ribbon cable.
      • Do not use excessive force and make sure the cameras ribbon cable gets properly re seated.
      Ask FixBot
2 other people completed this guide.
Author
with
Richard Bellizzi
352 Reputation
2 Guides authored
UMass Dartmouth, Team 1-6, Miles Fall 2015 Member of UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 98
All Time: 711
