Motorola Droid Motherboard Replacement
    1. Motorola Droid Motherboard Replacement, Battery: step 1, image 1 of 3 Motorola Droid Motherboard Replacement, Battery: step 1, image 2 of 3 Motorola Droid Motherboard Replacement, Battery: step 1, image 3 of 3
      • Slide the battery cover downwards while applying pressure to the center of the battery cover with your thumb.
      • Lift and remove the battery cover out from the phone.
      Ask FixBot
    2. Motorola Droid Motherboard Replacement: step 2, image 1 of 1
      • Grasp the upper left corner of the battery and lift it out of its housing.
      Ask FixBot
    1. Motorola Droid Motherboard Replacement, Rear Case: step 3, image 1 of 1
      • Use a spudger to lift and remove the black plastic screw cover at the top of the phone near the camera.
      • The cover is attached by adhesive, so some force may be required.
      Ask FixBot
    2. Motorola Droid Motherboard Replacement: step 4, image 1 of 2 Motorola Droid Motherboard Replacement: step 4, image 2 of 2
      • Using the tip of a spudger, peel up one corner of the gold ribbon beneath the battery compartment.
      • Peel the ribbon up off the phone.
      Ask FixBot
    3. Motorola Droid Motherboard Replacement: step 5, image 1 of 2 Motorola Droid Motherboard Replacement: step 5, image 2 of 2
      • Carefully peel the device information label that covers the motherboard EMI shields.
      • This label contains important information specific to the phone. Remove it with care and keep it in a safe place.
      Ask FixBot
    4. Motorola Droid Motherboard Replacement: step 6, image 1 of 1
      • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
      • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
      Ask FixBot
    5. Motorola Droid Motherboard Replacement: step 7, image 1 of 1
      • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
      Ask FixBot
    6. Motorola Droid Motherboard Replacement: step 8, image 1 of 1
      • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
      Ask FixBot
    7. Motorola Droid Motherboard Replacement: step 9, image 1 of 1
      • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
      • Carefully pry the top edge of the rear case up from the rest of the phone.
      Ask FixBot
    8. Motorola Droid Motherboard Replacement: step 10, image 1 of 2 Motorola Droid Motherboard Replacement: step 10, image 2 of 2
      • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
      • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
      Ask FixBot
    9. Motorola Droid Motherboard Replacement: step 11, image 1 of 2 Motorola Droid Motherboard Replacement: step 11, image 2 of 2
      • Continue prying the rear case from the front case along the left side, moving from bottom to top.
      • Lift the rear case up out of the phone.
      Ask FixBot
    1. Motorola Droid Motherboard Replacement, Speaker: step 12, image 1 of 1
      • Carefully lift and remove the speaker assembly up out of the phone.
      Ask FixBot
    1. Motorola Droid Motherboard Replacement, Motherboard: step 13, image 1 of 3 Motorola Droid Motherboard Replacement, Motherboard: step 13, image 2 of 3 Motorola Droid Motherboard Replacement, Motherboard: step 13, image 3 of 3
      • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
      • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
      Ask FixBot
    2. Motorola Droid Motherboard Replacement: step 14, image 1 of 1
      • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
      Ask FixBot
    3. Motorola Droid Motherboard Replacement: step 15, image 1 of 1
      • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
      Ask FixBot
    4. Motorola Droid Motherboard Replacement: step 16, image 1 of 1
      • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
      Ask FixBot
    5. Motorola Droid Motherboard Replacement: step 17, image 1 of 1
      • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
      • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
      Ask FixBot
    6. Motorola Droid Motherboard Replacement: step 18, image 1 of 2 Motorola Droid Motherboard Replacement: step 18, image 2 of 2
      • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
      • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
      • Remove the motherboard from the phone.
      Ask FixBot
8 other people completed this guide.
Brett Hartt
132,503 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
1 Guide Comment
Hi all,
Can anyone please suggest me should I dump my motorola droid. I have taken it to fix-it shops and they all have the same answer the mother board is gone
So, is it better to buy a new mother board which would cost me as much as a new phone or just sell it for nickels on Ebay
please reply pbansal1@jhu.edu
prateek - Reply Share
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 110
All Time: 29,849
