Up to 20% off select tools
Motorola Droid Mini Camera Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
88
All Time:
2,215
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The camera or flash may stop functioning or require eventual replacement. Here is a guide that offers that.
    1. Motorola Droid Mini Camera Replacement, Back Case: step 1, image 1 of 2 Motorola Droid Mini Camera Replacement, Back Case: step 1, image 2 of 2
      • Pull out the volume keys using the iFixit opening tool.
      Ask FixBot
    2. Motorola Droid Mini Camera Replacement: step 2, image 1 of 2 Motorola Droid Mini Camera Replacement: step 2, image 2 of 2
      • Pry off the back case gently using the iFixit opening tool.
      • Make sure to go around the entire perimeter of the case.
      Ask FixBot
    1. Motorola Droid Mini Camera Replacement, Camera: step 3, image 1 of 1
      • Use a T5 Torx screwdriver to unscrew the nine silver screws from the housing frame.
      Ask FixBot
    2. Motorola Droid Mini Camera Replacement: step 4, image 1 of 1
      • Carefully separate the housing frame from the motherboard.
      Ask FixBot
    3. Motorola Droid Mini Camera Replacement: step 5, image 1 of 2 Motorola Droid Mini Camera Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully use the tweezers to separate the motherboard from the screen.
      Ask FixBot
    4. Motorola Droid Mini Camera Replacement: step 6, image 1 of 2 Motorola Droid Mini Camera Replacement: step 6, image 2 of 2
      • Carefully use the tweezers to remove the flash motherboard.
      Ask FixBot
    5. Motorola Droid Mini Camera Replacement: step 7, image 1 of 2 Motorola Droid Mini Camera Replacement: step 7, image 2 of 2
      • Use tweezers to remove the camera from the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Alec Fales
337 Reputation
2 Guides authored
USF Tampa, Team 9-2, Leahy Fall 2014 Member of USF Tampa, Team 9-2, Leahy Fall 2014
USFT-LEAHY-F14S9G2
3 Members
60 Guides authored
2 Guide Comments
What’s the OEM number of the flash motherboard ‘coz my flash died and I want to buy a new one.
Any help is much appreciated!
creativeinventiondesign - Reply Share
Hey where can I buy a new camera for my motorola?
Shayna W - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 88
All Time: 2,215
