Motorola Droid MAXX 2 Screen Only Replacement
    1. Motorola Droid MAXX 2 Screen Only Replacement, Battery: step 1, image 1 of 1
      • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
      Ask FixBot
    2. Motorola Droid MAXX 2 Screen Only Replacement: step 2, image 1 of 1
      • Pull the sim card tray up out of the phone
      Ask FixBot
    3. Motorola Droid MAXX 2 Screen Only Replacement: step 3, image 1 of 2 Motorola Droid MAXX 2 Screen Only Replacement: step 3, image 2 of 2
      • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
      Ask FixBot
    4. Motorola Droid MAXX 2 Screen Only Replacement: step 4, image 1 of 1
      • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
      • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
      Ask FixBot
    5. Motorola Droid MAXX 2 Screen Only Replacement: step 5, image 1 of 1
      • Pull the mid-frame off of the phone.
      • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
      Ask FixBot
    6. Motorola Droid MAXX 2 Screen Only Replacement: step 6, image 1 of 3 Motorola Droid MAXX 2 Screen Only Replacement: step 6, image 2 of 3 Motorola Droid MAXX 2 Screen Only Replacement: step 6, image 3 of 3
      • Remove the static tape covering the two connectors.
      • Use a spudger to disconnect the battery cables from the motherboard.
      • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
      Ask FixBot
    7. Motorola Droid MAXX 2 Screen Only Replacement: step 7, image 1 of 1
      • Remove the disconnected battery from the phone.
      Ask FixBot
    1. Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: step 8, image 1 of 2 Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • We will be removing these 3 ribbon cables.
      • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
      • Use tweezers to lift up on the grey latch on the ZIF connector.
      • Remove the ribbon cable from the ZIF connector.
      Ask FixBot
    2. Motorola Droid MAXX 2 Screen Only Replacement: step 9, image 1 of 2 Motorola Droid MAXX 2 Screen Only Replacement: step 9, image 2 of 2
      • Use a pair of tweezers to lift up the black latch on the ZIF connector.
      • Pull the ribbon cable out of the ZIF connector.
      Ask FixBot
    3. Motorola Droid MAXX 2 Screen Only Replacement: step 10, image 1 of 3 Motorola Droid MAXX 2 Screen Only Replacement: step 10, image 2 of 3 Motorola Droid MAXX 2 Screen Only Replacement: step 10, image 3 of 3
      • Using a metal spudger, work your way around the perimeter of the main board and screen.
      • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
      Ask FixBot
    1. Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: step 11, image 1 of 2 Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: step 11, image 2 of 2
      • Use an opening pick or metal jimmy to carefully peel up a corner of this section of copper tape.
      • Slowly peel the entire piece of copper tape off of the frame, trying not to tear or kink it. Set aside and re-install after attaching new display.
      • Using the pointy tip of a spudger, detach these display cable tabs from the frame.
      Ask FixBot
    2. Motorola Droid MAXX 2 Screen Only Replacement: step 12, image 1 of 2 Motorola Droid MAXX 2 Screen Only Replacement: step 12, image 2 of 2
      • Carefully peel up the bottom part of this piece of copper tape and fold it over.
      • Using the point of a spudger, detach this display cable tab from the frame.
      Ask FixBot
      • The plastic edge around the digitizer is very fragile. Use caution when separating the adhesive.
      • Heat the top bezel to soften the adhesive and carefully start removing the display from the frame using a plastic opening picks and a metal jimmy as necessary.
      • The display cable is lightly adhered to the frame. Remove the display starting from the top.
      Ask FixBot
Patrick
6,782 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 765
