Up to 20% off select tools
Motorola Droid 4 SIM Card Replacement
Views: 4.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
98
All Time:
4,442
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
The SIM card stores important information on your phone. You should handle it with care when you are using this guide.
You will need to remove several torx head screws. Make sure to use the correct type.
    1. Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Removing Rear Panel: step 1, image 3 of 3
      • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
      • Slide the cover down to remove.
      Ask FixBot
    1. Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Lifting the SIM card cover: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers or your finger, lift the rubber SIM card cover to expose the card itself.
      Ask FixBot
    2. Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Removing SIM card: step 3, image 3 of 3
      • While holding the cover open, use your finger to press and slide out the SIM card.
      • When reinserting the SIM card, make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
      Ask FixBot
    3. Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 1 of 3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 2 of 3 Motorola Droid 4 SIM Card Replacement, Insert new SIM card: step 4, image 3 of 3
      • Follow the same steps in the opposite order to install the new SIM card.
      • Make sure the SIM card is oriented in the correct direction, according to the illustration on the device, and that the metal contact area of the card is facing down.
      Ask FixBot
Finish Line
Author
with
Javier
533 Reputation
4 Guides authored
USF Tampa, Team 5-1, Mcgee Fall 2014 Member of USF Tampa, Team 5-1, Mcgee Fall 2014
USFT-MCGEE-F14S5G1
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 98
All Time: 4,442
