Motorola Droid 4 Battery Replacement
    1. Motorola Droid 4 Battery Replacement, Removing Rear Panel: step 1, image 1 of 3 Motorola Droid 4 Battery Replacement, Removing Rear Panel: step 1, image 2 of 3 Motorola Droid 4 Battery Replacement, Removing Rear Panel: step 1, image 3 of 3
      • Insert the rear cover removal tool, or a paper clip, in the hole near the back camera lens.
      • Slide the cover down to remove.
      Ask FixBot
    1. Motorola Droid 4 Battery Replacement, Battery: step 2, image 1 of 1
      • Remove the sticker on the rear compartment to reveal the battery.
      • Hold the battery with your thumb while removing the sticker or you might end up ripping the battery out of the phone, damaging the flex cable.
      Ask FixBot
    2. Motorola Droid 4 Battery Replacement: step 3, image 1 of 2 Motorola Droid 4 Battery Replacement: step 3, image 2 of 2
      Tool used on this step:
      T5 Torx Screwdriver
      $5.49
      Buy
      • Use the T5 Torx Screwdriver to remove both 2.5 mm screws from the battery cable.
      • Use the Spudger to unstick the battery.
      • It's difficult to remove the battery without a pry tool like the spudger because of the strong adhesive. If you try removing it with just your fingers, the battery may bend.
      Ask FixBot
25 other people completed this guide.
Gaetan
9,631 Reputation
18 Guides authored
17 Guide Comments
Jerk at the verizon store said this wasnt possible and tried to sell me a new phone, dumbass. Thanks for the guide!!
Rose M - Reply Share
Worked great ! Ordered battery fro Amazon and with Torx kit...5 minute job !
Peter Kendrick - Reply Share
Peter- I ordered a replacement and was able to change the battery. However, once in place, the phone would not boot up and would only show the battery icon with a question mark in it. Did you run in to this problem?
Ed Barton - Reply Share
The battery in my phone started swelling so I ordered a battery from Amazon. Changing the battery was easy, but now the battery icon has a red question mark in it. How do I reset the battery icon?
Tracy - Reply Share
Tracy -
I had the same problem.... Will be buying a new battery, torx screwdriver, and spludger tool and replacing the battery soon. Then I can use the phone as a backup device, or a second phone (new service needed for new line), in case my new Moto X dies....
Chris
Chris - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 123
All Time: 40,998
