Motorola Droid 2 Rear Case Replacement
    1. Motorola Droid 2 Rear Case Replacement, Battery: step 1, image 1 of 3 Motorola Droid 2 Rear Case Replacement, Battery: step 1, image 2 of 3 Motorola Droid 2 Rear Case Replacement, Battery: step 1, image 3 of 3
      • Slide the battery cover toward the bottom edge of the phone.
      • Remove the battery cover from the rear of the phone.
      Ask FixBot
    2. Motorola Droid 2 Rear Case Replacement: step 2, image 1 of 2 Motorola Droid 2 Rear Case Replacement: step 2, image 2 of 2
      • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
      • Remove the battery from the Droid 2.
      Ask FixBot
    1. Motorola Droid 2 Rear Case Replacement, Rear Case: step 3, image 1 of 2 Motorola Droid 2 Rear Case Replacement, Rear Case: step 3, image 2 of 2
      • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
      • Peel the ribbon off the phone.
      Ask FixBot
    2. Motorola Droid 2 Rear Case Replacement: step 4, image 1 of 1
      • Insert the flat end of a spudger and pry the plastic camera cover up off the phone.
      • The thin plastic cover is attached to the phone with an adhesive. Work slowly and carefully.
      Ask FixBot
    3. Motorola Droid 2 Rear Case Replacement: step 5, image 1 of 1
      • Use the tip of a spudger to remove the camera bezel stuck to the rear case.
      Ask FixBot
    4. Motorola Droid 2 Rear Case Replacement: step 6, image 1 of 1
      • Remove the seven 5.5 mm T5 Torx screws securing the rear case to the inner case.
      Ask FixBot
    5. Motorola Droid 2 Rear Case Replacement: step 7, image 1 of 1
      • Insert the flat end of a spudger and pry downwards to release the plastic tab holding the rear case to the motherboard screw.
      Ask FixBot
    6. Motorola Droid 2 Rear Case Replacement: step 8, image 1 of 1
      • Gently insert a spudger between the rear case and front case at the top of the phone, near the audio jack.
      • Carefully pry the top edge of the rear case up from the rest of the phone.
      Ask FixBot
    7. Motorola Droid 2 Rear Case Replacement: step 9, image 1 of 2 Motorola Droid 2 Rear Case Replacement: step 9, image 2 of 2
      • With the spudger still inserted between the rear case and front case, slide the spudger along the right edge of the device, moving toward the bottom, prying as you go.
      • Continue prying along the bottom edge of the device from right to left, freeing it from the front panel.
      Ask FixBot
    8. Motorola Droid 2 Rear Case Replacement: step 10, image 1 of 2 Motorola Droid 2 Rear Case Replacement: step 10, image 2 of 2
      • Continue prying the rear case from the front case along the left side, moving from bottom to top.
      • Lift the rear case up out of the phone.
      • At this point, the button covers on the side of the phone are free and may fall out if you tip the phone upside down.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 41
All Time: 6,658
