Up to 20% off select tools
Motorola Defy XT Camera Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
5
Past 30 Days:
28
All Time:
1,328
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide shows the steps necessary to remove and install an integrated camera in the Motorola Defy XT mobile phone.
The Motorola Defy XT model has been discontinued.
    1. Motorola Defy XT Camera Replacement, Camera: step 1, image 1 of 1
      • Locate the opening on the corner of the Motorola Defy XT mobile phone.
      • Wedge the Plastic Opening Tool between the back cover and the body of the phone.
      Ask FixBot
    2. Motorola Defy XT Camera Replacement: step 2, image 1 of 1
      • Once wedged in the opening, gently pry around the phone until back cover lifts off.
      Ask FixBot
    3. Motorola Defy XT Camera Replacement: step 3, image 1 of 1
      • Remove the back cover and locate the battery.
      • Insert the opening tool beneath the battery and lightly push upward.
      Ask FixBot
    4. Motorola Defy XT Camera Replacement: step 4, image 1 of 1
      • Locate the SD card beneath the plastic cover in the corner.
      • Use a Plastic Opening Tool to hook the edge of the SD card
      Ask FixBot
    5. Motorola Defy XT Camera Replacement: step 5, image 1 of 1
      • Push the SD card straight out.
      Ask FixBot
    6. Motorola Defy XT Camera Replacement: step 6, image 1 of 1
      • Use the T4 Torque Driver to remove all 6 of the 3mm diameter screws on the outside edges of the phone.
      Ask FixBot
    7. Motorola Defy XT Camera Replacement: step 7, image 1 of 1
      • Wedge the Plastic Opening Tool under the inner side of the volume buttons.
      • Pop the volume buttons out of the phone.
      Ask FixBot
    8. Motorola Defy XT Camera Replacement: step 8, image 1 of 1
      • Locate the base of the motherboard.
      • Slide the Plastic Opening Tool along the base of the motherboard to separate it from the phone.
      • Gently guide the two pieces apart with upward motion.
      • Caution: Do not damage the ribbon that is holding both pieces
      Ask FixBot
    9. Motorola Defy XT Camera Replacement: step 9, image 1 of 1
      • Disconnect the ribbon from the frame.
      • Remove the screen.
      Ask FixBot
    10. Motorola Defy XT Camera Replacement: step 10, image 1 of 1
      • Flip the mother board over.
      • Locate the base of the ribbon cable.
      • Pull straight outward using the Plastic Opening Tool.
      • Disconnect the ribbon cable connecting the display to the logic board
      Ask FixBot
    11. Motorola Defy XT Camera Replacement: step 11, image 1 of 1
      • Pull the two halves of the device apart to disconnect the second (wider) ribbon connector.
      • Note: The ribbon connector is bonded to the logic board with adhesive, simply pull it to remove it completely.
      Ask FixBot
    12. Motorola Defy XT Camera Replacement: step 12, image 1 of 1
      • Use the Plastic Opening Tool to disconnect the camera from the logic board.
      Ask FixBot
Author
with
Mustapha Nadri
1 Reputation
1 Guide authored
Cal Poly, Team 2-22, Maness Spring 2013 Member of Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,328
