Motorola Cliq Motherboard Replacement
    1. Motorola Cliq Motherboard Replacement, Battery: step 1, image 1 of 2 Motorola Cliq Motherboard Replacement, Battery: step 1, image 2 of 2
      • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
      Ask FixBot
    2. Motorola Cliq Motherboard Replacement: step 2, image 1 of 2 Motorola Cliq Motherboard Replacement: step 2, image 2 of 2
      • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
      • The pull tab may be tucked under the battery.
      Ask FixBot
    1. Motorola Cliq Motherboard Replacement, Rear Casing: step 3, image 1 of 3 Motorola Cliq Motherboard Replacement, Rear Casing: step 3, image 2 of 3 Motorola Cliq Motherboard Replacement, Rear Casing: step 3, image 3 of 3
      • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
      • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
      Ask FixBot
    2. Motorola Cliq Motherboard Replacement: step 4, image 1 of 1
      • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
      Ask FixBot
    3. Motorola Cliq Motherboard Replacement: step 5, image 1 of 3 Motorola Cliq Motherboard Replacement: step 5, image 2 of 3 Motorola Cliq Motherboard Replacement: step 5, image 3 of 3
      • Turn the phone over and slide out the keyboard.
      • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
      • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
      • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
      Ask FixBot
    4. Motorola Cliq Motherboard Replacement: step 6, image 1 of 1
      • Carefully separate the back casing from the rest of the phone.
      Ask FixBot
    5. Motorola Cliq Motherboard Replacement: step 7, image 1 of 2 Motorola Cliq Motherboard Replacement: step 7, image 2 of 2
      • Gently pry ZIF connector upwards using the flat end of a spudger tool.
      • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
      • You may need adhesive to keep your power cable in place when reassembling your phone.
      Ask FixBot
    6. Motorola Cliq Motherboard Replacement: step 8, image 1 of 3 Motorola Cliq Motherboard Replacement: step 8, image 2 of 3 Motorola Cliq Motherboard Replacement: step 8, image 3 of 3
      • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
      • The rear casing and the rest of the phone should now be completely separated.
      Ask FixBot
    1. Motorola Cliq Motherboard Replacement, Motherboard: step 9, image 1 of 2 Motorola Cliq Motherboard Replacement, Motherboard: step 9, image 2 of 2
      • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
      Ask FixBot
    2. Motorola Cliq Motherboard Replacement: step 10, image 1 of 2 Motorola Cliq Motherboard Replacement: step 10, image 2 of 2
      • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
      Ask FixBot
    3. Motorola Cliq Motherboard Replacement: step 11, image 1 of 3 Motorola Cliq Motherboard Replacement: step 11, image 2 of 3 Motorola Cliq Motherboard Replacement: step 11, image 3 of 3
      • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
      Ask FixBot
3 other people completed this guide.
Tony Tran
84 Reputation
8 Guides authored
Cal Poly, Team 10-42, Amido Spring 2013 Member of Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 92
All Time: 1,207
