Motorola Cliq LCD Screen Replacement
    1. Motorola Cliq LCD Screen Replacement, Battery: step 1, image 1 of 2 Motorola Cliq LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
      Ask FixBot
    2. Motorola Cliq LCD Screen Replacement: step 2, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 2, image 2 of 2
      • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
      • The pull tab may be tucked under the battery.
      Ask FixBot
    1. Motorola Cliq LCD Screen Replacement, Rear Casing: step 3, image 1 of 3 Motorola Cliq LCD Screen Replacement, Rear Casing: step 3, image 2 of 3 Motorola Cliq LCD Screen Replacement, Rear Casing: step 3, image 3 of 3
      • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
      • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
      Ask FixBot
    2. Motorola Cliq LCD Screen Replacement: step 4, image 1 of 1
      • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
      Ask FixBot
    3. Motorola Cliq LCD Screen Replacement: step 5, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 5, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 5, image 3 of 3
      • Turn the phone over and slide out the keyboard.
      • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
      • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
      • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
      Ask FixBot
    4. Motorola Cliq LCD Screen Replacement: step 6, image 1 of 1
      • Carefully separate the back casing from the rest of the phone.
      Ask FixBot
    5. Motorola Cliq LCD Screen Replacement: step 7, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 7, image 2 of 2
      • Gently pry ZIF connector upwards using the flat end of a spudger tool.
      • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
      • You may need adhesive to keep your power cable in place when reassembling your phone.
      Ask FixBot
    6. Motorola Cliq LCD Screen Replacement: step 8, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 8, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 8, image 3 of 3
      • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
      • The rear casing and the rest of the phone should now be completely separated.
      Ask FixBot
    1. Motorola Cliq LCD Screen Replacement, Motherboard: step 9, image 1 of 2 Motorola Cliq LCD Screen Replacement, Motherboard: step 9, image 2 of 2
      • Wedge the plastic opening tool underneath the black display connector and pry it off its socket on the motherboard.
      Ask FixBot
    2. Motorola Cliq LCD Screen Replacement: step 10, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 10, image 2 of 2
      • Pry the orange keyboard connector from its socket on the motherboard using the edge of the plastic opening tool.
      Ask FixBot
    3. Motorola Cliq LCD Screen Replacement: step 11, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 11, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 11, image 3 of 3
      • Carefully grab the sides of the motherboard with your fingers and remove it from the phone.
      Ask FixBot
    1. Motorola Cliq LCD Screen Replacement, LCD Shield Plate: step 12, image 1 of 1
      • Remove the ten 3.0 mm T4 Torx screws near the black display cable.
      Ask FixBot
    2. Motorola Cliq LCD Screen Replacement: step 13, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 13, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 13, image 3 of 3
      • Orient the phone so that the edge closest to the camera points towards you and slide out the keyboard.
      • Wedge the tip of a spudger between the keyboard and the display assembly below the camera.
      • With steady pressure, pry the keyboard away from the display assembly.
      • The keyboard and display assembly are glued together, so expect some resistance.
      • Do not completely separate the keyboard and display assembly because the display flex cable still connects them.
      Ask FixBot
    3. Motorola Cliq LCD Screen Replacement: step 14, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 14, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 14, image 3 of 3
      • Grab the display flex cable and gently push it through the notch it is coming out of.
      Ask FixBot
    4. Motorola Cliq LCD Screen Replacement: step 15, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 15, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 15, image 3 of 3
      • Wedge a plastic opening tool underneath one of the metal panels on the underside of the display assembly.
      • Pry upwards and remove the metal panel.
      • Repeat this step for the second metal panel located on the opposite side of the phone.
      Ask FixBot
    5. Motorola Cliq LCD Screen Replacement: step 16, image 1 of 1
      • Remove the four 3.0 mm T4 Torx screws at the corners of the phone.
      Ask FixBot
    6. Motorola Cliq LCD Screen Replacement: step 17, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 17, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 17, image 3 of 3
      • Wedge a plastic opening tool between the edge and the black pastic cover on the underside of the display assembly.
      • Run the plastic opening tool along the edges to separate the black plastic cover from the display assembly.
      • Remove the black plastic cover.
      Ask FixBot
    7. Motorola Cliq LCD Screen Replacement: step 18, image 1 of 1
      • Remove the six 3.0 mm T4 Torx screws that align on the phone's sides.
      Ask FixBot
    8. Motorola Cliq LCD Screen Replacement: step 19, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 19, image 2 of 2
      • Insert a plastic opening tool between the LCD shield plate and a corner of the keyboard slider plate.
      • Pry apart the keyboard slider plate and LCD shield plate.
      • Do not completely separate them: the keyboard slider plate is still connected to the LCD shield plate via the display flex cable.
      Ask FixBot
    9. Motorola Cliq LCD Screen Replacement: step 20, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 20, image 2 of 2
      • Pry the display flex cable from its connector on the LCD shield plate with a plastic opening tool.
      • Separate the display flex cable from the LCD cover plate.
      Ask FixBot
    1. Motorola Cliq LCD Screen Replacement, LCD Screen: step 21, image 1 of 2 Motorola Cliq LCD Screen Replacement, LCD Screen: step 21, image 2 of 2
      • Pry off the flex cable located at the top right of the display assembly using the flat end of a spudger.
      Ask FixBot
    2. Motorola Cliq LCD Screen Replacement: step 22, image 1 of 2 Motorola Cliq LCD Screen Replacement: step 22, image 2 of 2
      • Turn the display on its side.
      • Carefully tilt the screen of the display until the digitizer starts to fall out.
      • Do not completely separate the digitizer just yet: it is still connected to the LCD case.
      Ask FixBot
    3. Motorola Cliq LCD Screen Replacement: step 23, image 1 of 3 Motorola Cliq LCD Screen Replacement: step 23, image 2 of 3 Motorola Cliq LCD Screen Replacement: step 23, image 3 of 3
      • With the digitizer held between two fingers, gently pull it away from the bottom of the phone until the digitizer flex cable has been completely removed from its socket.
      • Remove the digitizer.
      Ask FixBot
3 other people completed this guide.
Tony Tran
84 Reputation
8 Guides authored
Cal Poly, Team 10-42, Amido Spring 2013 Member of Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 26
All Time: 1,492
