Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓Use this guide to replace the keypad guard on the front of the phone.
Tools
Put the back case down on a table in front of you with the bottom of the phone close to you.
Put the key guard's tabs into the corresponding tabs on the bottom of the rear casing.
While the key guard's tabs are in the rear casing, put the rear casing's tabs into the bottom of the front casing.
Locate the holes that connect the keypad guard to the rear casing.
Find a thin and sturdy screwdriver.
Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
Use the screwdriver to push the rods away from each other until they click into a locked position.
