Motorola C350 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
93
All Time:
779
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the rubber keypad on your Motorola C350.
    1. Motorola C350 Keyboard Replacement, Rear case freeing: step 1, image 1 of 2 Motorola C350 Keyboard Replacement, Rear case freeing: step 1, image 2 of 2
      • Use your finger to press the button and free the device rear case.
      • You may have to force it a bit more to free its bottom if you open it for the first time.
      Ask FixBot
    1. Motorola C350 Keyboard Replacement, Removing battery: step 2, image 1 of 1
      • slide the black button to free the battery so you can grab it with your other hand.
      Ask FixBot
    1. Motorola C350 Keyboard Replacement, Separating the front case: step 3, image 1 of 2 Motorola C350 Keyboard Replacement, Separating the front case: step 3, image 2 of 2
      • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
      Ask FixBot
    1. Motorola C350 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Use your thumb to gently peel the keyboard off the front case.
      • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
      Ask FixBot
Vincent Monteil
7,031 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 93
All Time: 779
