Motorola C350 Display Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
106
All Time:
1,116
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Use this guide to replace the LCD in your Motorola C350.
Tools
    1. Motorola C350 Display Replacement, Rear case freeing: step 1, image 1 of 2 Motorola C350 Display Replacement, Rear case freeing: step 1, image 2 of 2
      • Use your finger to press the button and free the device rear case.
      • You may have to force it a bit more to free its bottom if you open it for the first time.
      Ask FixBot
    1. Motorola C350 Display Replacement, Removing battery: step 2, image 1 of 1
      • slide the black button to free the battery so you can grab it with your other hand.
      Ask FixBot
    1. Motorola C350 Display Replacement, Separating the front case: step 3, image 1 of 2 Motorola C350 Display Replacement, Separating the front case: step 3, image 2 of 2
      • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
      Ask FixBot
    1. Motorola C350 Display Replacement, Logic Board: step 4, image 1 of 2 Motorola C350 Display Replacement, Logic Board: step 4, image 2 of 2
      • Remove the 4 T6 Torx screws
      Ask FixBot
    2. Motorola C350 Display Replacement: step 5, image 1 of 2 Motorola C350 Display Replacement: step 5, image 2 of 2
      • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
      Ask FixBot
    3. Motorola C350 Display Replacement: step 6, image 1 of 1
      • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
      Ask FixBot
    1. Motorola C350 Display Replacement, Display: step 7, image 1 of 1
      • Remove the two small metal clips keeping the cables safe.
      Ask FixBot
    2. Motorola C350 Display Replacement: step 8, image 1 of 1
      • Use a plastic spudger to pell off the two cables on the back side of the screen.
      • There are two very small connectors. Take care of them and replace them if they incidentally fall.
      Ask FixBot
    3. Motorola C350 Display Replacement: step 9, image 1 of 1
      • Use a plastic spudger to release the disconnected screen.
      Ask FixBot
Vincent Monteil
7,031 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 106
All Time: 1,116
