Motorola C290 Logic Board Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
30
All Time:
1,923
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This repair guide will show how to get to the logic board and replace it
Tools
    1. Motorola C290 Logic Board Replacement, Battery: step 1, image 1 of 2 Motorola C290 Logic Board Replacement, Battery: step 1, image 2 of 2
      • Position Motorola C290 so that the back of the phone is facing up.
      • Apply pressure to the back cover while simultaneously sliding it downwards.
      • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
      Ask FixBot
    2. Motorola C290 Logic Board Replacement: step 2, image 1 of 2 Motorola C290 Logic Board Replacement: step 2, image 2 of 2
      • Place your finger in the notch at the top of the battery.
      • Gently lift and pull out battery.
      Ask FixBot
    1. Motorola C290 Logic Board Replacement, Antenna: step 3, image 1 of 3 Motorola C290 Logic Board Replacement, Antenna: step 3, image 2 of 3 Motorola C290 Logic Board Replacement, Antenna: step 3, image 3 of 3
      • Unscrew antenna head from top of phone by twisting counterclockwise.
      • Pull the antenna out through the top hole and set aside.
      Ask FixBot
    2. Motorola C290 Logic Board Replacement: step 4, image 1 of 2 Motorola C290 Logic Board Replacement: step 4, image 2 of 2
      • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
      Ask FixBot
    1. Motorola C290 Logic Board Replacement, Logic Board: step 5, image 1 of 3 Motorola C290 Logic Board Replacement, Logic Board: step 5, image 2 of 3 Motorola C290 Logic Board Replacement, Logic Board: step 5, image 3 of 3
      • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
      • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
      • Note: This will reveal a screw. Five screws should now be visible.
      • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
      Ask FixBot
    2. Motorola C290 Logic Board Replacement: step 6, image 1 of 2 Motorola C290 Logic Board Replacement: step 6, image 2 of 2
      • Insert the plastic opening tool in the groove at the top of the phone.
      • Rotate the tool to create an opening between the logic board cover and case.
      Ask FixBot
    3. Motorola C290 Logic Board Replacement: step 7, image 1 of 2 Motorola C290 Logic Board Replacement: step 7, image 2 of 2
      • Slide the plastic opening tool along the groove, until the entire logic board cover has been opened.
      • Remove logic board cover and set aside.
      Ask FixBot
    4. Motorola C290 Logic Board Replacement: step 8, image 1 of 1
      • Use the Spudger to detach the screen wire from the logic board.
      Ask FixBot
    5. Motorola C290 Logic Board Replacement: step 9, image 1 of 3 Motorola C290 Logic Board Replacement: step 9, image 2 of 3 Motorola C290 Logic Board Replacement: step 9, image 3 of 3
      • Insert the Spudger into the slot on the top of the logic board.
      • Gently pry to loosen the top of the logic board.
      • Note: The logic board may initially seem glued to the phone. It is not glued but does require input of force to remove.
      • Grab the top of the logic board and pull at an angle to remove.
      Ask FixBot
Paul
22 Reputation
1 Guide authored
Cal Poly, Team 24-28, Regan Spring 2010 Member of Cal Poly, Team 24-28, Regan Spring 2010
CPSU-REGAN-S10S24G28
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 1,923
