Motorola C261 Button Circuit Board Replacement
  1. Motorola C261 Button Circuit Board Replacement, Place Phone: step 1, image 1 of 1
    • Place the phone with the screen facedown on a flat surface.
    Ask FixBot
  2. Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: step 2, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Latch and Back Cover: step 2, image 2 of 2
    • Pinch the latch upwards towards the top of the phone.
    • Lift the back cover of the phone.
    • There are tabs on the bottom end of the battery cover that the cover pivots about.
    Ask FixBot
  3. Motorola C261 Button Circuit Board Replacement, Remove Battery: step 3, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Remove Battery: step 3, image 2 of 2
    • Remove the battery by pressing on the edge of the battery from the top of the phone towards the bottom and lifting up.
    Ask FixBot
  4. Motorola C261 Button Circuit Board Replacement, Screws in Rear Housing: step 4, image 1 of 1
    • Remove the four 8.5 mm screws from under the battery cover with a T4 Torx screwdriver.
    • Remove the two 8.5 mm screws from the top of the phone with a T4 Torx screwdriver.
    Ask FixBot
  5. Motorola C261 Button Circuit Board Replacement, Rear Housing: step 5, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Rear Housing: step 5, image 2 of 2
    • Using the plastic pry tool remove the rear housing from the rest of the phone. You may have to pry around all edges of the phone, not just the edge shown.
    • When you remove the rear housing, the rubber cover for the headphone jack/charge port may fall out. If not, remove it.
    Ask FixBot
  6. Motorola C261 Button Circuit Board Replacement, Spacers: step 6, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Spacers: step 6, image 2 of 2
    • Remove the small black circular rubber spacer.
    • Remove the white rubber spacer.
    • These pieces are small and easy to lose, especially the black one. Set them somewhere safe!
    Ask FixBot
  7. Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: step 7, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Motherboard and Front Housing: step 7, image 2 of 2
    • Gently remove the motherboard assembly from the front housing.
    • Now, the front housing is free to be replaced, as well as the cosmetic keypad.
    Ask FixBot
  8. Motorola C261 Button Circuit Board Replacement, Clips: step 8, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Clips: step 8, image 2 of 2
    • Remove the 2 clips from the sides of the phone, just below the screen with the pry tool.
    Ask FixBot
  9. Motorola C261 Button Circuit Board Replacement, Button Circuit Board: step 9, image 1 of 2 Motorola C261 Button Circuit Board Replacement, Button Circuit Board: step 9, image 2 of 2
    • The circuit board for the buttons is now free to be removed and replaced.
    Ask FixBot
Jason
305 Reputation
3 Guides authored
Michigan Tech, Team 1-6, Lauer Fall 2014 Member of Michigan Tech, Team 1-6, Lauer Fall 2014
MTU-LAUER-F14S1G6
3 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 362
