Up to 20% off select tools
Motorola C168 Front Panel Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
21
All Time:
1,505
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • T4 Torx Screwdriver
    4.8
  • Spudger
    4.9
    1. Motorola C168 Front Panel Replacement, Battery: step 1, image 1 of 2 Motorola C168 Front Panel Replacement, Battery: step 1, image 2 of 2
      • Turn the phone so its back is facing you.
      • Press the release button on the back cover, while simultaneously pulling the cover down.
      • Remove the back cover.
      Ask FixBot
    2. Motorola C168 Front Panel Replacement: step 2, image 1 of 2 Motorola C168 Front Panel Replacement: step 2, image 2 of 2
      • Pinch the sides of the bottom of the battery and pull upward.
      Ask FixBot
    1. Motorola C168 Front Panel Replacement, SIM Card: step 3, image 1 of 2 Motorola C168 Front Panel Replacement, SIM Card: step 3, image 2 of 2
      • Press and slide the SIM card down.
      • Remove the SIM card.
      Ask FixBot
    1. Motorola C168 Front Panel Replacement, Front Panel: step 4, image 1 of 2 Motorola C168 Front Panel Replacement, Front Panel: step 4, image 2 of 2
      • Orient the phone so its back is facing you.
      • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
      • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
      Ask FixBot
    2. Motorola C168 Front Panel Replacement: step 5, image 1 of 2 Motorola C168 Front Panel Replacement: step 5, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Lodge a spudger in between the front panel and the main frame of the phone.
      • Using a good amount of torque, pry the front panel from the phone.
      Ask FixBot
Author
with
Christopher Wu
37 Reputation
3 Guides authored
Cal Poly, Team 12-40, Regan Spring 2012 Member of Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,505
