Motorola C139 Antenna Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
44
All Time:
1,635
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
    1. Motorola C139 Antenna Replacement, Battery: step 1, image 1 of 3 Motorola C139 Antenna Replacement, Battery: step 1, image 2 of 3 Motorola C139 Antenna Replacement, Battery: step 1, image 3 of 3
      • Begin by flipping your phone over so that the back cover is facing up.
      • Apply force to the back cover and simultaneously slide the cover down.
      • Note: Applying pressure on the ridges will make it easier to remove the cover.
      Ask FixBot
    2. Motorola C139 Antenna Replacement: step 2, image 1 of 3 Motorola C139 Antenna Replacement: step 2, image 2 of 3 Motorola C139 Antenna Replacement: step 2, image 3 of 3
      • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
      • Lift and remove the battery.
      Ask FixBot
    1. Motorola C139 Antenna Replacement, SIM Card: step 3, image 1 of 3 Motorola C139 Antenna Replacement, SIM Card: step 3, image 2 of 3 Motorola C139 Antenna Replacement, SIM Card: step 3, image 3 of 3
      • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
      • Gently slide the SIM card out and lift to remove it from the phone.
      Ask FixBot
    1. Motorola C139 Antenna Replacement, Rear Casing: step 4, image 1 of 3 Motorola C139 Antenna Replacement, Rear Casing: step 4, image 2 of 3 Motorola C139 Antenna Replacement, Rear Casing: step 4, image 3 of 3
      • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
      • The screws are 6.86 mm long and 1.61 mm in diameter.
      Ask FixBot
    2. Motorola C139 Antenna Replacement: step 5, image 1 of 3 Motorola C139 Antenna Replacement: step 5, image 2 of 3 Motorola C139 Antenna Replacement: step 5, image 3 of 3
      • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
      • Repeat for the other side.
      Ask FixBot
    3. Motorola C139 Antenna Replacement: step 6, image 1 of 3 Motorola C139 Antenna Replacement: step 6, image 2 of 3 Motorola C139 Antenna Replacement: step 6, image 3 of 3
      • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
      • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
      • Release a total of six hooks from the sides and top to free the phone into two halves.
      Ask FixBot
    4. Motorola C139 Antenna Replacement: step 7, image 1 of 3 Motorola C139 Antenna Replacement: step 7, image 2 of 3 Motorola C139 Antenna Replacement: step 7, image 3 of 3
      • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
      • The screws are 6.86 mm long and 1.61mm in diameter.
      Ask FixBot
    5. Motorola C139 Antenna Replacement: step 8, image 1 of 3 Motorola C139 Antenna Replacement: step 8, image 2 of 3 Motorola C139 Antenna Replacement: step 8, image 3 of 3
      • Use plastic opening tools to free the circuit board from the case.
      • There are two hooks (one on each side) holding the circuit board into the case.
      • Then grip the circuit board and lift to remove the circuit board from the case.
      Ask FixBot
    1. Motorola C139 Antenna Replacement, Antenna: step 9, image 1 of 3 Motorola C139 Antenna Replacement, Antenna: step 9, image 2 of 3 Motorola C139 Antenna Replacement, Antenna: step 9, image 3 of 3
      • Unhook the antenna by releasing the two hooks, one on each side of the phone.
      • Detach the antenna from the back of the circuit board
      • This small black rubber cover may detach.
      Ask FixBot
Kyle Olbrich
33 Reputation
4 Guides authored
Clemson, Team 2-2, Benson Spring 2012 Member of Clemson, Team 2-2, Benson Spring 2012
CLEM-BENSON-S12S2G2
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
All Time: 1,635
