Motorola Buzz ic502 SIM card Replacement
  1. Motorola Buzz ic502 SIM card Replacement, Battery: step 1, image 1 of 3 Motorola Buzz ic502 SIM card Replacement, Battery: step 1, image 2 of 3 Motorola Buzz ic502 SIM card Replacement, Battery: step 1, image 3 of 3
    • First flip the phone over.
    • Then find the back release circled in red.
    Ask FixBot
  2. Motorola Buzz ic502 SIM card Replacement: step 2, image 1 of 2 Motorola Buzz ic502 SIM card Replacement: step 2, image 2 of 2
    • Carefully remove the back using the release.
    • Lift from the bottom!
    Ask FixBot
  3. Motorola Buzz ic502 SIM card Replacement: step 3, image 1 of 3 Motorola Buzz ic502 SIM card Replacement: step 3, image 2 of 3 Motorola Buzz ic502 SIM card Replacement: step 3, image 3 of 3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
    Ask FixBot
  4. Motorola Buzz ic502 SIM card Replacement, SIM card: step 4, image 1 of 3 Motorola Buzz ic502 SIM card Replacement, SIM card: step 4, image 2 of 3 Motorola Buzz ic502 SIM card Replacement, SIM card: step 4, image 3 of 3
    • The SIM card is located here
    • Carefully push the SIM card down from the top with your finger
    • Make sure to hold card from sides and do not touch the marked spot on card
    Ask FixBot
Austin Quinn
401 Reputation
4 Guides authored
UMass Dartmouth, Team 6-6, Martin Fall 2016 Member of UMass Dartmouth, Team 6-6, Martin Fall 2016
UMASSD-MARTIN-F16S6G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 362
