Motorola Atrix HD Rear Chassis Disassembly
    1. Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: step 1, image 1 of 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: step 1, image 2 of 3 Motorola Atrix HD Rear Chassis Disassembly, Rear Chassis: step 1, image 3 of 3
      • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
      • The adhesive strips may stay on the back cover or the battery.
      Ask FixBot
    2. Motorola Atrix HD Rear Chassis Disassembly: step 2, image 1 of 2 Motorola Atrix HD Rear Chassis Disassembly: step 2, image 2 of 2
      • The back case portion may be removed after the battery has been removed.
      • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
      Ask FixBot
    3. Motorola Atrix HD Rear Chassis Disassembly: step 3, image 1 of 3 Motorola Atrix HD Rear Chassis Disassembly: step 3, image 2 of 3 Motorola Atrix HD Rear Chassis Disassembly: step 3, image 3 of 3
      • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
      • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
      • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
      Ask FixBot
2 other people completed this guide.
Gabriel Agaman
597 Reputation
3 Guides authored
UMass Dartmouth, Team 1-8, Miles Fall 2015 Member of UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 102
All Time: 725
