Up to 20% off select tools
Motorola Atrix HD Battery Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
97
All Time:
4,078
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Parts
Introduction
Go to step 1 ↓
If you find that your battery no longer holds a charge, or is causing your phone to be inoperative, this guide will help you to replace it.
The battery may be removed with or without removing the back chassis. However you choose to remove it, take extra care when removing the ribbon cable attached to the motherboard, it is very thin and easily damaged.
    1. Motorola Atrix HD Battery Replacement, Battery: step 1, image 1 of 3 Motorola Atrix HD Battery Replacement, Battery: step 1, image 2 of 3 Motorola Atrix HD Battery Replacement, Battery: step 1, image 3 of 3
      • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
      • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
      • Continue working around the edge of the phone using the plastic opening tool.
      • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
      Ask FixBot
    2. Motorola Atrix HD Battery Replacement: step 2, image 1 of 1
      • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
      Ask FixBot
    3. Motorola Atrix HD Battery Replacement: step 3, image 1 of 3 Motorola Atrix HD Battery Replacement: step 3, image 2 of 3 Motorola Atrix HD Battery Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the red rubber screw cover with a pair of tweezers
      Ask FixBot
    4. Motorola Atrix HD Battery Replacement: step 4, image 1 of 2 Motorola Atrix HD Battery Replacement: step 4, image 2 of 2
      • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
      Ask FixBot
    5. Motorola Atrix HD Battery Replacement: step 5, image 1 of 1
      • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
      Ask FixBot
    6. Motorola Atrix HD Battery Replacement: step 6, image 1 of 3 Motorola Atrix HD Battery Replacement: step 6, image 2 of 3 Motorola Atrix HD Battery Replacement: step 6, image 3 of 3
      • Use the plastic opening tool around the edges to loosen the battery.
      • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
      Ask FixBot
    7. Motorola Atrix HD Battery Replacement: step 7, image 1 of 1
      • The battery may now be removed.
      Ask FixBot
4 other people completed this guide.
Author
with
Bradley Hinckley
561 Reputation
2 Guides authored
UMass Dartmouth, Team 1-8, Miles Fall 2015 Member of UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Members
60 Guides authored
1 Guide Comment
How do you calibrate it then? Lights up green dot, charges, won't work! Multi tester shows full power.
jvandeputte - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 97
All Time: 4,078
