Up to 20% off select tools
Motorola Atrix HD Touchscreen and LCD Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
104
All Time:
1,712
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Tools
Introduction
Go to step 1 ↓
The most common damage to phones today are cracked touchscreens and damaged LCD displays. If your Atrix HD suffered damage to one or both of these items this guide will show you how to replace them. The simplicity of the Atrix HD construction will allow you to replace these components with as little as two tools, a T5 torx driver, and a plastic opening tool.
    1. Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: step 1, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: step 1, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: step 1, image 3 of 3
      • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
      • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
      • Continue working around the edge of the phone using the plastic opening tool.
      • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
      Ask FixBot
    2. Motorola Atrix HD  Touchscreen and LCD Replacement: step 2, image 1 of 1
      • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
      Ask FixBot
    3. Motorola Atrix HD  Touchscreen and LCD Replacement: step 3, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 3, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the red rubber screw cover with a pair of tweezers
      Ask FixBot
    4. Motorola Atrix HD  Touchscreen and LCD Replacement: step 4, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement: step 4, image 2 of 2
      • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
      Ask FixBot
    5. Motorola Atrix HD  Touchscreen and LCD Replacement: step 5, image 1 of 1
      • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
      Ask FixBot
    6. Motorola Atrix HD  Touchscreen and LCD Replacement: step 6, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 6, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 6, image 3 of 3
      • Use the plastic opening tool around the edges to loosen the battery.
      • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
      Ask FixBot
    7. Motorola Atrix HD  Touchscreen and LCD Replacement: step 7, image 1 of 1
      • The battery may now be removed.
      Ask FixBot
    1. Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: step 8, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: step 8, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: step 8, image 3 of 3
      • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
      • The adhesive strips may stay on the back cover or the battery.
      Ask FixBot
    2. Motorola Atrix HD  Touchscreen and LCD Replacement: step 9, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement: step 9, image 2 of 2
      • The back case portion may be removed after the battery has been removed.
      • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
      Ask FixBot
    3. Motorola Atrix HD  Touchscreen and LCD Replacement: step 10, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 10, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 10, image 3 of 3
      • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
      • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
      • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
      Ask FixBot
    1. Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: step 11, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: step 11, image 2 of 2
      • Begin by removing the 10 Torx T5 motherboard baseplate screws
      • The back chassis can now be removed.
      Ask FixBot
    2. Motorola Atrix HD  Touchscreen and LCD Replacement: step 12, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement: step 12, image 2 of 2
      • Remove the 10 Torx T5 screws, that hold the metal frame to the motherboard.
      Ask FixBot
    3. Motorola Atrix HD  Touchscreen and LCD Replacement: step 13, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 13, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 13, image 3 of 3
      • After following the steps to access the motherboard, you are ready to remove the touchscreen and LCD display.
      • Use the plastic opening tool to separate the LCD display from the motherboard.
      • The touchscreen may separate from the LCD, however they are both connected to the motherboard as one unit.
      Ask FixBot
    4. Motorola Atrix HD  Touchscreen and LCD Replacement: step 14, image 1 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 14, image 2 of 3 Motorola Atrix HD  Touchscreen and LCD Replacement: step 14, image 3 of 3
      • Remove the ribbon cable from the back of the lcd using the plastic opening tool or spudger.
      • Use care removing the ribbon cables. They are very thin and are broken easily.
      Ask FixBot
    5. Motorola Atrix HD  Touchscreen and LCD Replacement: step 15, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement: step 15, image 2 of 2
      • Remove the ribbon cable connecting the LCD display to the motherboard, be mindful that the ribbon cable is very thin.
      • With the LCD display removed, remove the ribbon cable connecting the touchscreen to the motherboard
      Ask FixBot
    6. Motorola Atrix HD  Touchscreen and LCD Replacement: step 16, image 1 of 2 Motorola Atrix HD  Touchscreen and LCD Replacement: step 16, image 2 of 2
      • The LCD display and the touchscreen may now be replaced.
      Ask FixBot
4 other people completed this guide.
Author
with
Gabriel Agaman
597 Reputation
3 Guides authored
UMass Dartmouth, Team 1-8, Miles Fall 2015 Member of UMass Dartmouth, Team 1-8, Miles Fall 2015
UMASSD-MILES-F15S1G8
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 104
All Time: 1,712
