Introduction
To remove the speaker you will first need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver, spudger and head gun or hair dryer.
Tool used on this step:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
Tool used on this step:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
Tool used on this step:Spudger$3.99
Insert a spudger between the black plastic and the motherboard.
Lift upwards with the spudger to dislodge the board.
Remove the rubber cover located directly over the speaker.
Peel off the orange adhesive strip using fingernails or the spudger. This must be done to remove the top speaker.
Insert the spudger under the top speaker and use it to lift the speaker out of place.
Be careful when removing the top speaker from its housing because it is still connected to the phone. You must undo the connection before complete removal.
To undo the connector, lift the black flap on the edge closest to the speaker, and then the cable slides out
9 other people completed this guide.
