Motorola Atrix 4G Bottom Speaker Replacement
    1. Motorola Atrix 4G Bottom Speaker Replacement, Battery: step 1, image 1 of 1
      • Pry the back cover off the back of the phone.
      Ask FixBot
    2. Motorola Atrix 4G Bottom Speaker Replacement: step 2, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement: step 2, image 2 of 2
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Insert a spudger into the small notch at the base of the battery.
      • Lift the battery out of the phone.
      Ask FixBot
    1. Motorola Atrix 4G Bottom Speaker Replacement, Antenna: step 3, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement, Antenna: step 3, image 2 of 2
      T5 Torx Screwdriver
      $5.49
      Buy
      • Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
      • Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
      • Use gentle force while unscrewing to avoid stripping the screws.
      Ask FixBot
    2. Motorola Atrix 4G Bottom Speaker Replacement: step 4, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      Ask FixBot
    3. Motorola Atrix 4G Bottom Speaker Replacement: step 5, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement: step 5, image 2 of 2
      iFixit Opening Tool
      $1.99
      Buy
      • Gently lift the tabs located at the top of the phone using an opening tool.
      • Gently lift the tab located at the bottom of the phone with the same tool.
      • Use an opening tool, not your fingers, because the plastic tabs are easily broken.
      Ask FixBot
    4. Motorola Atrix 4G Bottom Speaker Replacement: step 6, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement: step 6, image 2 of 2
      iFixit Opening Tool
      $1.99
      Buy
      • Insert an opening tool between the front and back of the case.
      • Slide the tool down the side of the phone.
      • Repeat the same process for the other side.
      • There should be a noticeable gap between the front and back cases. If not, repeat this step.
      Ask FixBot
    5. Motorola Atrix 4G Bottom Speaker Replacement: step 7, image 1 of 1
      • Carefully lift the back case off the phone.
      • Do not completely separate the back case from the phone. The antenna is connected to both cases.
      Ask FixBot
    6. Motorola Atrix 4G Bottom Speaker Replacement: step 8, image 1 of 1
      iFixit Opening Tool
      $1.99
      Buy
      • Slide an opening tool beneath the antenna and lift straight up from the motherboard.
      • Lift straight upwards, not at an angle, to avoid damaging the socket underneath.
      Ask FixBot
    7. Motorola Atrix 4G Bottom Speaker Replacement: step 9, image 1 of 1
      • Ease the antenna from out of its guide along the side of the phone
      • Remove the back case and the antenna from the phone.
      • The antenna is soldered to the back case. When reassembling, do not pull it with too much force.
      Ask FixBot
    1. Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: step 10, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: step 10, image 2 of 2
      Spudger
      $3.99
      Buy
      • Insert a spudger between the black plastic and the motherboard.
      • Lift upwards with the spudger to dislodge the board.
      • The motherboard should lift up easily. If the white rubber piece shifts, move it back to its original place.
      Ask FixBot
    2. Motorola Atrix 4G Bottom Speaker Replacement: step 11, image 1 of 1
      Spudger
      $3.99
      Buy
      • Disconnect the press connectors using a spudger.
      • If you are unfamiliar with using connectors, consult this guide.
      Ask FixBot
    3. Motorola Atrix 4G Bottom Speaker Replacement: step 12, image 1 of 1
      Spudger
      $3.99
      Buy
      • Lift the white latch on the ZIF connector using a spudger.
      • Gently pull the black ribbon down and away from the latch.
      Ask FixBot
    4. Motorola Atrix 4G Bottom Speaker Replacement: step 13, image 1 of 1
      • There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
      Ask FixBot
    1. Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: step 14, image 1 of 2 Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: step 14, image 2 of 2
      • The speaker can be found on the bottom of the inside of the back case and is held in by glue.
      • Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
      Ask FixBot
2 other people completed this guide.
Jake
515 Reputation
2 Guides authored
Cal Poly, Team 9-42, Regan Spring 2012 Member of Cal Poly, Team 9-42, Regan Spring 2012
CPSU-REGAN-S12S9G42
6 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 36
All Time: 3,972
