Moto Z Fingerprint Sensor Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Moto Z Fingerprint Sensor Replacement, Display: step 1, image 1 of 2 Moto Z Fingerprint Sensor Replacement, Display: step 1, image 2 of 2
      • Position the opening tool under the lid of the screen.
      • Slide the opening tool around the edge of the screen to loosen the adhesive.
      Ask FixBot
    2. Moto Z Fingerprint Sensor Replacement: step 2, image 1 of 1
      • Lift the screen off the body from the top.
      Ask FixBot
    3. Moto Z Fingerprint Sensor Replacement: step 3, image 1 of 2 Moto Z Fingerprint Sensor Replacement: step 3, image 2 of 2
      • To disconnect the screen from the body, stick the spudger under one of the corners of the gold tab.
      • Lift up, removing the tab from the device.
      Ask FixBot
    4. Moto Z Fingerprint Sensor Replacement: step 4, image 1 of 1
      • Pull the screen up to fully remove it.
      Ask FixBot
    1. Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 1 of 2 Moto Z Fingerprint Sensor Replacement, Fingerprint Sensor: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Insert the tweezers under the metal backing of the sensor.
      • Lift up the backing until it is detached from the phone.
      Ask FixBot
    2. Moto Z Fingerprint Sensor Replacement: step 6, image 1 of 2 Moto Z Fingerprint Sensor Replacement: step 6, image 2 of 2
      • With the tweezers, grab the black connector located just above the fingerprint scanner.
      • Pull the connector to the right until it is detached from the phone.
      Ask FixBot
Miriam Lam
1,188 Reputation
5 Guides authored
Cal Poly, Team S2-G2, Livingston Winter 2018 Member of Cal Poly, Team S2-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 22
All Time: 585
