Moto G4 Vibration Motor Replacement
    1. Moto G4 Vibration Motor Replacement, Back Cover: step 1, image 1 of 3 Moto G4 Vibration Motor Replacement, Back Cover: step 1, image 2 of 3 Moto G4 Vibration Motor Replacement, Back Cover: step 1, image 3 of 3
      • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
      • Gently twist or pry to open a small gap between the back cover and the body of the phone.
      • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
      Ask FixBot
    2. Moto G4 Vibration Motor Replacement: step 2, image 1 of 2 Moto G4 Vibration Motor Replacement: step 2, image 2 of 2
      • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
      Ask FixBot
    3. Moto G4 Vibration Motor Replacement: step 3, image 1 of 3 Moto G4 Vibration Motor Replacement: step 3, image 2 of 3 Moto G4 Vibration Motor Replacement: step 3, image 3 of 3
      • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
      • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
      Ask FixBot
    4. Moto G4 Vibration Motor Replacement: step 4, image 1 of 2 Moto G4 Vibration Motor Replacement: step 4, image 2 of 2
      • Remove the back cover.
      • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
      Ask FixBot
    1. Moto G4 Vibration Motor Replacement, Midframe: step 5, image 1 of 3 Moto G4 Vibration Motor Replacement, Midframe: step 5, image 2 of 3 Moto G4 Vibration Motor Replacement, Midframe: step 5, image 3 of 3
      • Push to eject and remove the MicroSD and SIM cards (if installed).
      Ask FixBot
    2. Moto G4 Vibration Motor Replacement: step 6, image 1 of 2 Moto G4 Vibration Motor Replacement: step 6, image 2 of 2
      • Use a spudger to pry up the rubber cover for the camera flash connector.
      Ask FixBot
    3. Moto G4 Vibration Motor Replacement: step 7, image 1 of 1
      • Remove the rubber cover.
      Ask FixBot
    4. Moto G4 Vibration Motor Replacement: step 8, image 1 of 2 Moto G4 Vibration Motor Replacement: step 8, image 2 of 2
      • Use a spudger to disconnect the camera flash connector by prying it straight up.
      Ask FixBot
    5. Moto G4 Vibration Motor Replacement: step 9, image 1 of 1
      • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
      Ask FixBot
    6. Moto G4 Vibration Motor Replacement: step 10, image 1 of 1
      • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
      Ask FixBot
    7. Moto G4 Vibration Motor Replacement: step 11, image 1 of 1
      • Remove the midframe.
      Ask FixBot
    1. Moto G4 Vibration Motor Replacement, Battery Disconnection: step 12, image 1 of 2 Moto G4 Vibration Motor Replacement, Battery Disconnection: step 12, image 2 of 2
      • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
      • Gently pry straight up to disconnect the battery.
      • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
      • During reassembly, align the connector in its socket and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
      Ask FixBot
    1. Moto G4 Vibration Motor Replacement, Vibration Motor: step 13, image 1 of 2 Moto G4 Vibration Motor Replacement, Vibration Motor: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Pull black flap on bottom of motherboard back.
      • Use tweezers to pop vibration motor off of motherboard.
      Ask FixBot
Nathan Granger
202 Reputation
2 Guides authored
USF Tampa, Team S15-G3, Boczar Spring 2018 Member of USF Tampa, Team S15-G3, Boczar Spring 2018
USFT-BOCZAR-S18S15G3
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 72
All Time: 1,210
