Introduction
Go to step 1 ↓Use this guide to remove the motherboard with the cameras and headphone jack attached from your Motorola Moto C Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Tools
Spudger4.9
Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
Lever the battery out of its recess and remove it.
Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
9 other people completed this guide.
1 Guide Comment
roderyjose9@gmail como hago para encender este mismo teléfono sin el botón de encendido
