Moto C Plus Daughterboard Replacement
    1. Moto C Plus Daughterboard Replacement, Back Cover: step 1, image 1 of 3 Moto C Plus Daughterboard Replacement, Back Cover: step 1, image 2 of 3 Moto C Plus Daughterboard Replacement, Back Cover: step 1, image 3 of 3
      • Power off your phone before beginning disassembly.
      • Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
      • Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
      Ask FixBot
    2. Moto C Plus Daughterboard Replacement: step 2, image 1 of 2 Moto C Plus Daughterboard Replacement: step 2, image 2 of 2
      • Lift the phone out of the back cover.
      Ask FixBot
    1. Moto C Plus Daughterboard Replacement, Battery: step 3, image 1 of 3 Moto C Plus Daughterboard Replacement, Battery: step 3, image 2 of 3 Moto C Plus Daughterboard Replacement, Battery: step 3, image 3 of 3
      • Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
      • Lever the battery out of its recess and remove it.
      Ask FixBot
    1. Moto C Plus Daughterboard Replacement, Daughterboard Cover: step 4, image 1 of 1
      • Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
      Ask FixBot
    2. Moto C Plus Daughterboard Replacement: step 5, image 1 of 3 Moto C Plus Daughterboard Replacement: step 5, image 2 of 3 Moto C Plus Daughterboard Replacement: step 5, image 3 of 3
      • Apply a spudger to the right side of the daughterboard cover.
      • Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
      • Remove the daughterboard cover.
      Ask FixBot
    1. Moto C Plus Daughterboard Replacement, Daughterboard: step 6, image 1 of 2 Moto C Plus Daughterboard Replacement, Daughterboard: step 6, image 2 of 2
      • Disconnect the antenna cable and fold it out of the way.
      Ask FixBot
    2. Moto C Plus Daughterboard Replacement: step 7, image 1 of 2 Moto C Plus Daughterboard Replacement: step 7, image 2 of 2
      • Use the tip of a spudger to open the brown flap of the ZIF connector that holds the interconnect cable in its place.
      • When reassembling make sure the white line on the cable aligns with the closed flap.
      Ask FixBot
    3. Moto C Plus Daughterboard Replacement: step 8, image 1 of 2 Moto C Plus Daughterboard Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
      Ask FixBot
    4. Moto C Plus Daughterboard Replacement: step 9, image 1 of 1
      • Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
      Ask FixBot
    5. Moto C Plus Daughterboard Replacement: step 10, image 1 of 3 Moto C Plus Daughterboard Replacement: step 10, image 2 of 3 Moto C Plus Daughterboard Replacement: step 10, image 3 of 3
      • Apply an opening pick to the bottom edge of the daughterboard.
      • Carefully slide the opening pick under the daughterboard to cut the adhesive underneath.
      • Take care to cut the adhesive underneath the vibration motor.
      • Slide the opening pick from right to left to cut all the adhesive.
      Ask FixBot
    6. Moto C Plus Daughterboard Replacement: step 11, image 1 of 1
      • Remove the daughterboard including the soldered-on vibration motor.
      Ask FixBot
Apply new adhesive where it’s necessary.
Dominik Schnabelrauch
266,083 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 60
All Time: 1,182
