Up to 20% off select tools
Motion Computing LE1600 Speaker Modules Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
108
All Time:
1,891
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If you're having sound issues, your speakers may be broken. Follow these steps to replace them.
    1. Motion Computing LE1600 Speaker Modules Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the screen is facing down.
      Ask FixBot
    2. Motion Computing LE1600 Speaker Modules Replacement: step 2, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 2, image 2 of 2
      • Slide the battery lock switch next to the power slider to the unlocked position.
      Ask FixBot
    3. Motion Computing LE1600 Speaker Modules Replacement: step 3, image 1 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 3, image 2 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 3, image 3 of 3
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
      Ask FixBot
    1. Motion Computing LE1600 Speaker Modules Replacement, Bluetooth Module: step 4, image 1 of 1
      • Unscrew hard drive panel using a Phillips head #1 screwdriver.
      • (Our device was not given to us with a hard drive or a hard drive panel)
      Ask FixBot
    2. Motion Computing LE1600 Speaker Modules Replacement: step 5, image 1 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 5, image 2 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 5, image 3 of 3
      • Pull clear plastic tab to detach hard drive from tablet.
      Ask FixBot
    3. Motion Computing LE1600 Speaker Modules Replacement: step 6, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 6, image 2 of 2
      • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
      Ask FixBot
    4. Motion Computing LE1600 Speaker Modules Replacement: step 7, image 1 of 1
      • Pull the brown tabs to disconnect the white ribbon cable on the other side.
      Ask FixBot
    5. Motion Computing LE1600 Speaker Modules Replacement: step 8, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 8, image 2 of 2
      • Caution: do not pull on the wires, instead pull from the plastic connectors.
      • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
      Ask FixBot
    6. Motion Computing LE1600 Speaker Modules Replacement: step 9, image 1 of 1
      • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
      Ask FixBot
    7. Motion Computing LE1600 Speaker Modules Replacement: step 10, image 1 of 1
      • Using a spudger, press in the five tabs on the side where the battery was.
      • This should separate the two halves of the device. Carefully set the side with the display off to the side.
      Ask FixBot
    8. Motion Computing LE1600 Speaker Modules Replacement: step 11, image 1 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 11, image 2 of 3 Motion Computing LE1600 Speaker Modules Replacement: step 11, image 3 of 3
      • Locate the Bluetooth board.
      • Disconnect the ribbon cable by pulling on the plastic connector.
      Ask FixBot
    9. Motion Computing LE1600 Speaker Modules Replacement: step 12, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 12, image 2 of 2
      • Unscrew the 4mm screw holding the board onto the tablet.
      • Lift the board out of the tablet and carefully set it aside.
      Ask FixBot
    1. Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: step 13, image 1 of 3 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: step 13, image 2 of 3 Motion Computing LE1600 Speaker Modules Replacement, Speaker Modules: step 13, image 3 of 3
      • Locate speaker connectors on tablet and unplug them by pulling on the plastic heads.
      Ask FixBot
    2. Motion Computing LE1600 Speaker Modules Replacement: step 14, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 14, image 2 of 2
      • To remove the speaker near the network port, unscrew the two black 4mm screws securing it to the tablet and pull away.
      Ask FixBot
    3. Motion Computing LE1600 Speaker Modules Replacement: step 15, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 15, image 2 of 2
      • To remove the speaker near the headphone jack, unscrew the one 4mm black screw securing it to the tablet.
      Ask FixBot
    4. Motion Computing LE1600 Speaker Modules Replacement: step 16, image 1 of 2 Motion Computing LE1600 Speaker Modules Replacement: step 16, image 2 of 2
      • Unstick the white masking tape and the black electrical tape holding the black and red wire down.
      • Pull out the wire and speaker.
      Ask FixBot
Author
with
David Troy
44 Reputation
3 Guides authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 108
All Time: 1,891
