Up to 20% off select tools
Motion Computing LE1600 Bluetooth Module Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
105
All Time:
3,237
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If the wireless Bluetooth for the LE1600 does not work, you may need to replace it. This guide will take you through the steps to replace the Bluetooth module for your LE1600.
    1. Motion Computing LE1600 Bluetooth Module Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the screen is facing down.
      Ask FixBot
    2. Motion Computing LE1600 Bluetooth Module Replacement: step 2, image 1 of 2 Motion Computing LE1600 Bluetooth Module Replacement: step 2, image 2 of 2
      • Slide the battery lock switch next to the power slider to the unlocked position.
      Ask FixBot
    3. Motion Computing LE1600 Bluetooth Module Replacement: step 3, image 1 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 3, image 2 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 3, image 3 of 3
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
      Ask FixBot
    1. Motion Computing LE1600 Bluetooth Module Replacement, Bluetooth Module: step 4, image 1 of 1
      • Unscrew hard drive panel using a Phillips head #1 screwdriver.
      • (Our device was not given to us with a hard drive or a hard drive panel)
      Ask FixBot
    2. Motion Computing LE1600 Bluetooth Module Replacement: step 5, image 1 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 5, image 2 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 5, image 3 of 3
      • Pull clear plastic tab to detach hard drive from tablet.
      Ask FixBot
    3. Motion Computing LE1600 Bluetooth Module Replacement: step 6, image 1 of 2 Motion Computing LE1600 Bluetooth Module Replacement: step 6, image 2 of 2
      • To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
      Ask FixBot
    4. Motion Computing LE1600 Bluetooth Module Replacement: step 7, image 1 of 1
      • Pull the brown tabs to disconnect the white ribbon cable on the other side.
      Ask FixBot
    5. Motion Computing LE1600 Bluetooth Module Replacement: step 8, image 1 of 2 Motion Computing LE1600 Bluetooth Module Replacement: step 8, image 2 of 2
      • Caution: do not pull on the wires, instead pull from the plastic connectors.
      • To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
      Ask FixBot
    6. Motion Computing LE1600 Bluetooth Module Replacement: step 9, image 1 of 1
      • With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
      Ask FixBot
    7. Motion Computing LE1600 Bluetooth Module Replacement: step 10, image 1 of 1
      • Using a spudger, press in the five tabs on the side where the battery was.
      • This should separate the two halves of the device. Carefully set the side with the display off to the side.
      Ask FixBot
    8. Motion Computing LE1600 Bluetooth Module Replacement: step 11, image 1 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 11, image 2 of 3 Motion Computing LE1600 Bluetooth Module Replacement: step 11, image 3 of 3
      • Locate the Bluetooth board.
      • Disconnect the ribbon cable by pulling on the plastic connector.
      Ask FixBot
    9. Motion Computing LE1600 Bluetooth Module Replacement: step 12, image 1 of 2 Motion Computing LE1600 Bluetooth Module Replacement: step 12, image 2 of 2
      • Unscrew the 4mm screw holding the board onto the tablet.
      • Lift the board out of the tablet and carefully set it aside.
      Ask FixBot
Author
with
David Troy
44 Reputation
3 Guides authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
60 Guides authored
1 Guide Comment
thanks for the help
Lawrence V Lang - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 105
All Time: 3,237
