Up to 20% off select tools
Motion Computing LE1600 Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
111
All Time:
3,561
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Before you start anything, you should always remove the battery. This guide will take you through this process.
    1. Motion Computing LE1600 Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the screen is facing down.
      Ask FixBot
    2. Motion Computing LE1600 Battery Replacement: step 2, image 1 of 2 Motion Computing LE1600 Battery Replacement: step 2, image 2 of 2
      • Slide the battery lock switch next to the power slider to the unlocked position.
      Ask FixBot
    3. Motion Computing LE1600 Battery Replacement: step 3, image 1 of 3 Motion Computing LE1600 Battery Replacement: step 3, image 2 of 3 Motion Computing LE1600 Battery Replacement: step 3, image 3 of 3
      • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
      • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
      Ask FixBot
Author
with
David Troy
44 Reputation
3 Guides authored
Cal Poly, Team 15-14, Forte Spring 2012 Member of Cal Poly, Team 15-14, Forte Spring 2012
CPSU-FORTE-S12S15G14
5 Members
60 Guides authored
1 Guide Comment
Wow that’s so cool thanks bro
Leon Byrne - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 111
All Time: 3,561
