Up to 20% off select tools
Motherboard Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
109
All Time:
1,026
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This task requires the removal of small screws. Be sure you have a secure place to keep the screws such as a magnetic mat.
    1. Motherboard Replacement, Back Cover: step 1, image 1 of 3 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Motherboard Replacement, Back Cover: step 1, image 3 of 3
      • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
      • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
      • Avoid prying on the buttons, as they are easily damaged.
      Ask FixBot
    2. Motherboard Replacement: step 2, image 1 of 1
      • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
      Ask FixBot
    1. Motherboard Replacement, Battery: step 3, image 1 of 1
      • Remove masking tape from the battery.
      Ask FixBot
    2. Motherboard Replacement: step 4, image 1 of 3 Motherboard Replacement: step 4, image 2 of 3 Motherboard Replacement: step 4, image 3 of 3
      • Pry the battery from the base using the nylon spudger and move it away from the motherboard.
      • Handle the battery with care to avoid damaging it.
      Ask FixBot
    3. Motherboard Replacement: step 5, image 1 of 3 Motherboard Replacement: step 5, image 2 of 3 Motherboard Replacement: step 5, image 3 of 3
      • De-solder the three contact points and remove the battery.
      • See the following guide for instructions on how to solder. How To Solder and Desolder Connections
      • Use caution when operating the soldering iron.
      Ask FixBot
    1. Motherboard Replacement, Motherboard: step 6, image 1 of 3 Motherboard Replacement, Motherboard: step 6, image 2 of 3 Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Remove the two ZIF connectors attached to the motherboard by flipping up the black tabs before pulling the ribbon cable away.
      • Only use a fingernail or nylon spudger to flip up the retaining flap. Using metal tools may damage delicate components.
      Ask FixBot
    2. Motherboard Replacement: step 7, image 1 of 1
      • Use the nut driver and J00 bit to remove the three 4 mm screws.
      Ask FixBot
    3. Motherboard Replacement: step 8, image 1 of 3 Motherboard Replacement: step 8, image 2 of 3 Motherboard Replacement: step 8, image 3 of 3
      • Peel back metal tape that is hiding the auxiliary port wires.
      • Remove tape that is holding the speaker wires in place.
      • Lift up on the motherboard to release it from the tablet.
      Ask FixBot
Author
with
Connor Fisher
212 Reputation
1 Guide authored
Baylor, Team 4-1, Williams Fall 2016 Member of Baylor, Team 4-1, Williams Fall 2016
BU-WILLIAMS-F16S4G1
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 109
All Time: 1,026
