Up to 20% off select tools
Motherboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
100
All Time:
1,610
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 3 - 4 minutes
Difficulty: Difficult
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the motherboard in the Fellowes T7CM.
    1. Motherboard Replacement, Fellowes T7CM Casing and Trigger Replacement: step 1, image 1 of 1
      • Check to make sure the shredder is not plugged in to any electrical outlet.
      • Remove the shredder from the catch basket and place the silver side down on a flat surface.
      • Place the catch basket aside as you will not be needing it for the rest of the disassembly.
      Ask FixBot
    2. Motherboard Replacement: step 2, image 1 of 1
      • Flip the shredder silver side down and place on a flat even surface.
      • Remove the manufacturer's label in order to gain access to the hidden screw hole.
      • Locate all five of the case screws and remove them with a Phillips-Head screwdriver. The screws are located within the five marked circles in the photo. The size of the screws are 18 mm in length and head diameter of 5 mm.
      Ask FixBot
    3. Motherboard Replacement: step 3, image 1 of 1
      • Once all of the screws are removed, slowly pull apart the casing.
      • If the casing is not separating, gently wiggle the top part of the casing from the bottom part of the casing.
      • Use Caution during this procedure to prevent from damaging any of the internal parts.
      Ask FixBot
    4. Motherboard Replacement: step 4, image 1 of 1
      • Open the casing as shown to prevent tangling or damaging the wires.
      • Take note to how the trigger assembly is attached before removal.
      • The trigger assembly is one part and should come off all together with little to no force applied.
      • Remove the trigger assembly.
      Ask FixBot
    1. Motherboard Replacement, On,  Off, Reverse Switch: step 5, image 1 of 1
      • Unscrew both of the screws from the circuit board of the switch . Lift the circuit board away from the device. The screw length is 10 mm and the head diameter is 6 mm.
      Ask FixBot
    2. Motherboard Replacement: step 6, image 1 of 2 Motherboard Replacement: step 6, image 2 of 2
      • Remove the plastic switch case.
      • After the plastic case is removed, the switch can be replaced.
      • During the switch replacement, be careful of the springs that are held in side. They can potentially come loose and get lost.
      Ask FixBot
    1. Motherboard Replacement, Motherboard: step 7, image 1 of 2 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Desolder the wires from the motherboard. Learn more about soldering componentshere!
      Ask FixBot
    2. Motherboard Replacement: step 8, image 1 of 1
      • After all of the wires are removed, the motherboard can be lifted off and removed with ease.
      Ask FixBot
Author
with
John Wisthoff
487 Reputation
3 Guides authored
IUPUI, Team 2-2, Baechle Fall 2016 Member of IUPUI, Team 2-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 100
All Time: 1,610
