This teardown is not a repair guide. To repair your Morris 57030 multimeter, use our service manual.
  1. Morris 57030 multimeter LCD repair, Morris 57030 multimeter LCD repair: step 1, image 1 of 1
    • Remove the two screws from the back of the meter to open it.
    Ask FixBot
    • Remove the three screws on the circuit board to remove the circuit board from the body. Be careful not to lose the two small ball bearings that sit on springs on the underside of the circuit board that hold the dial in position.
    Ask FixBot
  2. Morris 57030 multimeter LCD repair: step 3, image 1 of 1
    • Remove the black plastic LCD and backlight frame from the top of the circuit board by pushing and releasing the small black plastic pins that protrude through the circuit board. The picture is not in good focus, it shows copper tabs at the top of circuit board and the LCD and polymer strip in the black plastic frame in the background
    Ask FixBot
    • Remove the pinkish conductive polymer strip from the black plastic LCD frame.
    Ask FixBot
    • Wipe both edges of the polymer strip with an alcohol wipe. Then wipe the corresponding section of small copper conductors at the top of the circuit board that make contact with the polymer strip.
    Ask FixBot
    • Replace the polymer strip into the LCD frame making sure it firmly contacts the LCD screen. Then clip the LCD frame back in place on the circuit board by pushing the 4 black plastic pins through the square holes in the circuit board. Make sure the polymer strip makes solid contact with the circuit board.
    Ask FixBot
    • Reverse the steps to put the meter back together.
    Ask FixBot
John Koella
170 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 26
All Time: 324
