Monster SoundStage S1 Mini Speaker Replacement
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: step 1, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: step 1, image 2 of 2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
    Ask FixBot
  2. Monster SoundStage S1 Mini Speaker Replacement: step 2, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 2, image 2 of 2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
    Ask FixBot
  3. Monster SoundStage S1 Mini Speaker Replacement: step 3, image 1 of 1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
    Ask FixBot
  4. Monster SoundStage S1 Mini Speaker Replacement: step 4, image 1 of 3 Monster SoundStage S1 Mini Speaker Replacement: step 4, image 2 of 3 Monster SoundStage S1 Mini Speaker Replacement: step 4, image 3 of 3
    • Solder the black plastic encasing the red and black wires.
    Ask FixBot
  5. Monster SoundStage S1 Mini Speaker Replacement: step 5, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 5, image 2 of 2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
    Ask FixBot
  6. Monster SoundStage S1 Mini Speaker Replacement: step 6, image 1 of 2 Monster SoundStage S1 Mini Speaker Replacement: step 6, image 2 of 2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
    Ask FixBot
Heather Carrillo
412 Reputation
2 Guides authored
CSU Fullerton, Team 2-6, Bruce Fall 2016 Member of CSU Fullerton, Team 2-6, Bruce Fall 2016
CSUF-BRUCE-F16S2G6
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 29
All Time: 778
