Moen Posi-Temp Cartridge Part #1112b Replacement
    1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: step 1, image 1 of 1
      • Turn the water shutoff valve counter-clockwise to the "off" position.
      Ask FixBot
    2. Moen Posi-Temp Cartridge Part #1112b Replacement: step 2, image 1 of 1
      • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
      Ask FixBot
    3. Moen Posi-Temp Cartridge Part #1112b Replacement: step 3, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 3, image 2 of 2
      • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
      Ask FixBot
    4. Moen Posi-Temp Cartridge Part #1112b Replacement: step 4, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 4, image 2 of 2
      • Unscrew the handle screw with an Allen wrench.
      • Remove the handle.
      Ask FixBot
    5. Moen Posi-Temp Cartridge Part #1112b Replacement: step 5, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 5, image 2 of 2
      • Remove the handle adaptor screw with a Phillips screwdriver.
      • Remove the handle adaptor simply by pulling it out.
      Ask FixBot
    6. Moen Posi-Temp Cartridge Part #1112b Replacement: step 6, image 1 of 1
      • Pull out the white key/adjustable limit stop.
      Ask FixBot
    7. Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 7, image 3 of 3
      • Gently pull out the stop tube.
      Ask FixBot
    8. Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 8, image 3 of 3
      • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
      • Remove the metal plate.
      Ask FixBot
    9. Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 9, image 3 of 3
      • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
      Ask FixBot
    10. Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 1 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 2 of 3 Moen Posi-Temp Cartridge Part #1112b Replacement: step 10, image 3 of 3
      • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
      Ask FixBot
    11. Moen Posi-Temp Cartridge Part #1112b Replacement: step 11, image 1 of 2 Moen Posi-Temp Cartridge Part #1112b Replacement: step 11, image 2 of 2
      • Insert the new Moen Posi-Temp cartridge.
      Ask FixBot
    12. Moen Posi-Temp Cartridge Part #1112b Replacement: step 12, image 1 of 1
      • Insert the new cartridge into the valve assembly.
      • Ensure that the H/C symbols are facing up.
      • Ensure that the notch on the brass tube is also facing up.
      Ask FixBot
John Mendoza
237 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 117
All Time: 2,551
