Up to 20% off select tools
Model O- Mouse Cable Replacement
Views: 15K
View statistics:
Past 24 Hours:
5
Past 7 Days:
38
Past 30 Days:
196
All Time:
14,756
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If your mouse is intermittently disconnecting, randomly missing movements and inputs - you might have a broken or damaged mouse cable. The mouse cable carries data from the mouse to your computer. A damaged cable can result in missed mouse movements and inputs. Before starting this guide try a different connector (most likely USB) port on your computer, and inspect the connector for dirt and debris.
This guide shows an easy, step-by-step process on how to replace the mouse cable in a Glorious Model O- mouse.
The mouse should be physically unplugged from your computer prior to beginning your repair.
    1. Model O- Mouse Cable Replacement, Mouse Cable: step 1, image 1 of 3 Model O- Mouse Cable Replacement, Mouse Cable: step 1, image 2 of 3 Model O- Mouse Cable Replacement, Mouse Cable: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Turn the mouse over so that the feet are facing you.
      • Remove the bottom two mouse feet using tweezers.
      • If you plan on reusing the mouse feet place them with the adhesive side up.
      Ask FixBot
    2. Model O- Mouse Cable Replacement: step 2, image 1 of 2 Model O- Mouse Cable Replacement: step 2, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
      Ask FixBot
    3. Model O- Mouse Cable Replacement: step 3, image 1 of 3 Model O- Mouse Cable Replacement: step 3, image 2 of 3 Model O- Mouse Cable Replacement: step 3, image 3 of 3
      • Slide the base away from the top housing to avoid the front clips.
      • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
      • Avoid putting strain on the thin LED ribbon cables.
      Ask FixBot
    4. Model O- Mouse Cable Replacement: step 4, image 1 of 2 Model O- Mouse Cable Replacement: step 4, image 2 of 2
      • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
      • Do not pull on the wires.
      • Remove the cable from around the circuit board and from the hole on the front of the mouse.
      Ask FixBot
    5. Model O- Mouse Cable Replacement: step 5, image 1 of 2 Model O- Mouse Cable Replacement: step 5, image 2 of 2
      • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
      • Do not push on the wires.
      Ask FixBot
    6. Model O- Mouse Cable Replacement: step 6, image 1 of 2 Model O- Mouse Cable Replacement: step 6, image 2 of 2
      • Route the new cable through the slit in the circuit board.
      • Route the new cable behind the pillars.
      • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
      • The cable may not stay in place until the top housing is securely fastened back on.
      Ask FixBot
    7. Model O- Mouse Cable Replacement: step 7, image 1 of 2 Model O- Mouse Cable Replacement: step 7, image 2 of 2
      • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
      • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
      Ask FixBot
    8. Model O- Mouse Cable Replacement: step 8, image 1 of 1
      • Screw the two screws back in with a Phillips #0 screwdriver.
      • Do not apply too much force or you risk stripping the screw holes.
      Ask FixBot
    9. Model O- Mouse Cable Replacement: step 9, image 1 of 2 Model O- Mouse Cable Replacement: step 9, image 2 of 2
      • Reapply the mouse feet with the adhesive side sticking to the mouse.
      • There are plastic ridges to help guide the user where to place the mouse feet.
      • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Theo SW
265 Reputation
1 Guide authored
2 Guide Comments
Where can I get the replacement cable for it?
Ekke Sten - Reply Share
does glorius them selfs sell replacment parts ?
aniss-97 - Reply Share
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 196
All Time: 14,756
