Up to 20% off select tools
Modal MD-WORCSS6 Motor Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
80
All Time:
602
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The motor replacement guide for the MODAL WORCSS6 walks through the process for disassembling the device, removing the motor from its wire connections, and correctly replacing the motor. The motor provides the forces that press and rotate the screw into the cork of your wine bottle (or sparkling apple juice!). The motor should be replaced if the device fails to provide this singular function. Soldering will be required to replace the motor, so check out our How to Solder and Desolder Connections guide if you are unfamiliar with the process.
    1. Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 1 of 2 Modal MD-WORCSS6 Motor Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 2 of 2
      • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
      • Using the jimmy tool, carefully pry off the black plastic ring.
      • Remove the spring assembly from inside the transparent plastic tube.
      Ask FixBot
    2. Modal MD-WORCSS6 Motor Replacement: step 2, image 1 of 2 Modal MD-WORCSS6 Motor Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
      • Take the plastic tube off of the metal casing.
      Ask FixBot
    3. Modal MD-WORCSS6 Motor Replacement: step 3, image 1 of 2 Modal MD-WORCSS6 Motor Replacement: step 3, image 2 of 2
      • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
      • With the button assembly removed, slide off the metal casing.
      Ask FixBot
    4. Modal MD-WORCSS6 Motor Replacement: step 4, image 1 of 3 Modal MD-WORCSS6 Motor Replacement: step 4, image 2 of 3 Modal MD-WORCSS6 Motor Replacement: step 4, image 3 of 3
      • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
      • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
      Ask FixBot
    5. Modal MD-WORCSS6 Motor Replacement: step 5, image 1 of 3 Modal MD-WORCSS6 Motor Replacement: step 5, image 2 of 3 Modal MD-WORCSS6 Motor Replacement: step 5, image 3 of 3
      • Carefully peel the tape off far enough to remove the 3 batteries.
      Ask FixBot
    1. Modal MD-WORCSS6 Motor Replacement, Motor: step 6, image 1 of 3 Modal MD-WORCSS6 Motor Replacement, Motor: step 6, image 2 of 3 Modal MD-WORCSS6 Motor Replacement, Motor: step 6, image 3 of 3
      • Slide the circuit board out of its slot.
      • Pull the white plastic neck down and out of the slot. Remove the neck and body spring.
      Ask FixBot
    2. Modal MD-WORCSS6 Motor Replacement: step 7, image 1 of 1
      • Use wire cutters to cut the wires connected to the bottom of the motor.
      • Remove the motor from the plastic body.
      Ask FixBot
    3. Modal MD-WORCSS6 Motor Replacement: step 8, image 1 of 1
      • Strip the insulation from the wire up to about half an inch from the end of the exposed wire.
      • Attach a new motor to the device by re-soldering the connections that were cut earlier.
      • Check out our How to Solder and Desolder Connections guide for best practices and soldering tips.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 80
All Time: 602
