Up to 20% off select tools
Modal MD-WORCSS6 Battery Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
92
All Time:
1,915
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The following steps in this guide explains how to replace the batteries in the MODAL WORCSS6 wine opener. The batteries inside the MODAL WORCSS6 wine opener are rechargeable, but they can burn out or lose their ability to hold a charge with age. The batteries are an essential part of the wine opener and give power to the motor and LED lights.
    1. Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 1 of 2 Modal MD-WORCSS6 Battery Replacement, Modal MD-WORCSS6 Teardown Guide: step 1, image 2 of 2
      • Put on Electrostatic Discharge (ESD) bracelet. Hold the device with the transparent plastic casing on the top.
      • Using the jimmy tool, carefully pry off the black plastic ring.
      • Remove the spring assembly from inside the transparent plastic tube.
      Ask FixBot
    2. Modal MD-WORCSS6 Battery Replacement: step 2, image 1 of 2 Modal MD-WORCSS6 Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, unscrew each of the four 12.7 mm screws inside and at the bottom of the plastic tube.
      • Take the plastic tube off of the metal casing.
      Ask FixBot
    3. Modal MD-WORCSS6 Battery Replacement: step 3, image 1 of 2 Modal MD-WORCSS6 Battery Replacement: step 3, image 2 of 2
      • Place the jimmy tool blade between the button assembly and the metal casing. Gently pry off the button assembly; it should pop out.
      • With the button assembly removed, slide off the metal casing.
      Ask FixBot
    4. Modal MD-WORCSS6 Battery Replacement: step 4, image 1 of 3 Modal MD-WORCSS6 Battery Replacement: step 4, image 2 of 3 Modal MD-WORCSS6 Battery Replacement: step 4, image 3 of 3
      • Unscrew the two 6.4 mm screws in the black plastic body using the Phillips #1 screwdriver.
      • Separate the two halves of the plastic body. Keep the half containing the motor facing up.
      Ask FixBot
    5. Modal MD-WORCSS6 Battery Replacement: step 5, image 1 of 3 Modal MD-WORCSS6 Battery Replacement: step 5, image 2 of 3 Modal MD-WORCSS6 Battery Replacement: step 5, image 3 of 3
      • Carefully peel the tape off far enough to remove the 3 batteries.
      Ask FixBot
    1. Modal MD-WORCSS6 Battery Replacement, Battery: step 6, image 1 of 1
      • Replace the batteries by pulling them out of their holder and putting new ones in the same places.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Where do you get the replacement batteries?
Gerry David - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 92
All Time: 1,915
