Modal MD-SPBT01 Speaker Wiring Replacement
  1. Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: step 1, image 1 of 2 Modal MD-SPBT01 Speaker Wiring Replacement, Speaker Wiring: step 1, image 2 of 2
    • Use the plastic opening tool to pull the metal cover off the top of the speaker.
  2. Modal MD-SPBT01 Speaker Wiring Replacement: step 2, image 1 of 1
    • Remove the four screws that are inside the holes on the top of the speaker.
    • Use a Phillips 00 screwdriver to remove the 10mm screws.
  3. Modal MD-SPBT01 Speaker Wiring Replacement: step 3, image 1 of 1
    • Pull the top piece of the speaker off to allow access to the interior.
  4. Modal MD-SPBT01 Speaker Wiring Replacement: step 4, image 1 of 1
    • Locate the speaker wire connection and remove the wiring.
    • Locate the LED lighting wire and remove that as well.
  5. Modal MD-SPBT01 Speaker Wiring Replacement: step 5, image 1 of 1
    • Once you disconnect the wires, you can remove the speaker.
  6. Modal MD-SPBT01 Speaker Wiring Replacement: step 6, image 1 of 2 Modal MD-SPBT01 Speaker Wiring Replacement: step 6, image 2 of 2
    • Remove the positive and negative connections for the wiring to fully disconnect the wire.
    • Now that you have removed the defective wiring, you can install a new one.
Nathan Hall
258 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 37
All Time: 668
