Up to 20% off select tools
ModRetro Transparent Chromatic Disassembly
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
208
All Time:
324
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This step-by-step disassembly guide is intended for ModRetro Transparent Chromatic units.
Use this guide when modifying or replacing components on the Chromatic.
    1. ModRetro Transparent Chromatic Disassembly, Battery Cover and Batteries: step 1, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Battery Cover and Batteries: step 1, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Battery Cover and Batteries: step 1, image 3 of 3
      • To remove the battery cover, push upward on the battery cover lock. The battery cover will pop open.
      • Lift the battery cover off and set aside.
      • Remove the batteries and set aside.
      Ask FixBot
    2. ModRetro Transparent Chromatic Disassembly, Back Shell: step 2, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Back Shell: step 2, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Back Shell: step 2, image 3 of 3
      • Remove the back shell screws (x4) using a Tri-wing Y1 Screwdriver.
      • A Tri-wing Y1.5 will also work for all screws.
      • The screws near the top are a different length from the screws near the bottom of the shell.
      • Remove the back shell by lifting away from the device.
      Ask FixBot
    3. ModRetro Transparent Chromatic Disassembly, Menu Button: step 3, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Menu Button: step 3, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Menu Button: step 3, image 3 of 3
      • Remove the menu button by lifting it off the post. It should come off with no resistance.
      • When reassembling, slot the hole of the button onto the post.
      Ask FixBot
    4. ModRetro Transparent Chromatic Disassembly, Battery Tray: step 4, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Battery Tray: step 4, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Battery Tray: step 4, image 3 of 3
      • Remove the battery tray screws (x3) using a Tri-wing Y1 Screwdriver.
      • Lift the battery tray off and set aside.
      Ask FixBot
    5. ModRetro Transparent Chromatic Disassembly, PCB: step 5, image 1 of 2 ModRetro Transparent Chromatic Disassembly, PCB: step 5, image 2 of 2
      • Carefully disconnect the LCD screen ribbon cable from the PCB.
      • Handle with care!
      • Carefully remove the PCB from the front shell.
      • Lifting at a slight angle will help clear the headphone jack on the bottom more easily. During reassembly, seat the headphone jack on the bottom of the PCB into the shell first.
      • When reassembling, ensure both the power button and the power switch on the PCB are set to the OFF position. Misalignment can permanently damage the PCB.
      Ask FixBot
    6. ModRetro Transparent Chromatic Disassembly, Rubber Retainer: step 6, image 1 of 2 ModRetro Transparent Chromatic Disassembly, Rubber Retainer: step 6, image 2 of 2
      • The rubber retainer may stick to the PCB during removal. Because it is small, it can easily be overlooked or lost. Double-check that you have it before moving on.
      • For reassembly, slot the rubber retainer onto the two positive features at the bottom of the shell. The front face of the rubber retainer should sit flat against the bottom of the front shell before inserting the PCB.
      Ask FixBot
    7. ModRetro Transparent Chromatic Disassembly, Speaker Module: step 7, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Speaker Module: step 7, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Speaker Module: step 7, image 3 of 3
      • Carefully remove the speaker module from the front shell and set aside.
      • For reassembly, check the orientation to make sure the ModRetro logo faces the front shell.
      Ask FixBot
    8. ModRetro Transparent Chromatic Disassembly, Buttons and Membranes: step 8, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Buttons and Membranes: step 8, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Buttons and Membranes: step 8, image 3 of 3
      • Remove the rubber button membranes (x3) from their pockets.
      • Remove the buttons and the D-pad from the shell with tweezers or by hand. If you flip the shell over, they will fall out freely.
      • When reattaching the rubber button membranes, ensure that the positive features on the membranes are seated securely into the pockets on the shell.
      Ask FixBot
    9. ModRetro Transparent Chromatic Disassembly, IR Window: step 9, image 1 of 3 ModRetro Transparent Chromatic Disassembly, IR Window: step 9, image 2 of 3 ModRetro Transparent Chromatic Disassembly, IR Window: step 9, image 3 of 3
      • Carefully separate the IR window by firmly pulling it away from the front shell.
      • For reassembly, check the orientation to make sure the side with the front lip goes in first.
      • Press in firmly until the IR window is seated securely.
      • If the IR window fits loosely, the orientation is incorrect. The fit should be snug.
      Ask FixBot
    10. ModRetro Transparent Chromatic Disassembly, Power Switch: step 10, image 1 of 2 ModRetro Transparent Chromatic Disassembly, Power Switch: step 10, image 2 of 2
      • Remove the power switch by pulling it away from the front shell. It should come off with little resistance.
      • When reassembling the power switch, make sure it is inserted in the OFF position (2nd image).
      Ask FixBot
    11. ModRetro Transparent Chromatic Disassembly, Cartridge Backer: step 11, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Cartridge Backer: step 11, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Cartridge Backer: step 11, image 3 of 3
      • Remove the cartridge backer screws (x4) using a Tri-wing Y1 screwdriver.
      • Pull the backer away from the front shell and set it aside. Note that there will be some resistance around the charm loops on each side.
      Ask FixBot
    12. ModRetro Transparent Chromatic Disassembly, Battery Cover: step 12, image 1 of 3 ModRetro Transparent Chromatic Disassembly, Battery Cover: step 12, image 2 of 3 ModRetro Transparent Chromatic Disassembly, Battery Cover: step 12, image 3 of 3
      • Remove the screws (x2) securing the latch cover using a Tri-wing Y1 screwdriver.
      • Remove the door plate spring by fully depressing the battery cover lock. The spring should pop out.
      • Use a spudger if the spring does not fully dislodge.
      • Once the spring is removed, the battery cover lock lifts out easily.
      Ask FixBot
tmai_modretro
409 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 208
All Time: 324
